Hot Rods Ford T-5 Flathead HELP
Discussion in 'The Hokey Ass Message Board' started by spencer boehm, Sep 28, 2019.
  1. spencer boehm
    spencer boehm
    I have a 1950 flathead. I want to use the ford t5 I have from a mustang. What is the cheapest way to adapt this.
  2. V8 Bob
    V8 Bob
    Depends on the bell housing you're using. The '49- '53 Ford/'51-'53 Mercury 4-bolt bells can use a 1" adapter.
  3. spencer boehm
    spencer boehm
    who makes this adapter plate? I do not have much expense in the flat head world
  4. V8 Bob
    V8 Bob
    Modern Driveline (MDL).
  5. spencer boehm
    spencer boehm
    Thank you. Is the
    Thank you. Is there any other options?
  6. V8 Bob
    V8 Bob
    There may be, but I don't know of any at this time.
  7. hotrodlane
    hotrodlane
    Yes, Buy you a 1" thick 10 X 10 piece of 6061 Aluminum and make it yourself. Or source a buddy with a lathe that will swing the 10 X 10 plate or a Mill. I can send you a drawing that was shared with me for the Plate. It's actually a pretty straight forward piece.
    Tim likes this.
  8. Bandit Billy
    Bandit Billy
    http://www.wilcap.com/flathead.html
    I bought mine from Wilcap. "Cheap" and "flathead" are terms rarely used in one sentence. I bought the Wilcap because I wanted the best.
  9. seb fontana
    seb fontana
    from ct
    Which ever you use check the concentric of the locating bore and flatness once installed. I had a trans issue and thought I had assembled the trans wrong so replaced with brand new untouched by me and am at the start of the same trans issue and suspect the adapter.
  10. Mr48chev
    If you have the stamped steel 49/53 Flathead car bellhousing and a Ford T 5 this is the one that Billy was linking to.
