I have a later model 302 ford in my chevy nova subframe and have adapted the lines already. I keep hearing that the ford pump will have too much pressure for the Chevy box but everything I read is Chevy is the higher pressure pump.. Anyone else using a ford pump to Chevy steering box? My pump is out of a Crown Vic 5.0 w/ serpentine belt if it matters. I also tried the search option and didnt find anything. thank you
Anyone ? I am having issues with the steering lately someone told me that the chevy saginaw steering box may have a check valve in it and the ford sterring pump might have a valve in it and they are fighting eachother? someone shed some light on this for me?
i have a later 302 and ford pump running with a s10 box and it is actually a little slower than it was with the chevy p pump, fords have less psi than the chevys. i like the way mine feels, its just a hair heavier feeling than it was before
I have a Camaro clip in my truck with a 302 sbf. I'm just gonna use the gm pump.I got a set of double groove pulley's for the crank and water pump and gonna make the brackets to fit on the driver side. It looks doable.
I am researching putting a power steering pump on my flathead. From my learnings, The Chevy pump needs a restrictor or something in it if used on a Ford box. That would go with Supervert's comment about the ford pump not being as good on the S10 box. I guess other than a little sluggishness at low rpm, the Ford pump should drive the S10 box fine. You could get a saginaw pump and adapt it? I think these guys still make an adapter. http://marchperf.com/pg30.html This guy has a how to. http://www.azbronco.org/tech08.htm I googled "Ford 5.0 saginaw power steering pump" and got those and other good links to look at... this thread showed up there, oddly enough.
Some Ford 351 engines ran Saginaw pumps. Here is a link on doing the mods to fit a Saginaw pump to a 302 Ford engine. Had to go over to the 4X4 boys to find it though. http://classicbroncos.com/saginaw.shtml Or what looks like the easy but not cheap way out http://www.tomsbroncoparts.com/product.php?id=977
mine steers great, even at idle. the chevy p pump is only like 1 or 200 psi higher than the ford pump. i dont like the one finger steering that chevys have, so for me the ford pump and chevy box is a great combo. i do run the chevy p pump on my yota crawler and the toyota system is lower psi than the ford system and i dont have any problams with it either
I hooked up the Ford pump on the 460 in my truck to a saginaw box I have'nt driven it a lot but it seems to work fine.
the goal is to use what is set up on my engine now wich is 91 crown vic pump I would like to find out if there is a check valve in either one or? I raised my front end last night and i cannot push the tires back and forth to turn. i disconnected the lines and then i can move them and the fluid pushed out the pressure line side. i rehooked up lines and again cannot move tires. i can reach down and turn the rag joint and turn it and the wheels turn with ease? lost yet? me too...
Found the problem I had a heim joint seized to the shaft so I just re designed it all with the use of some harley axle adusters and the ford steering pump to chevy gear box is working real nice now... Did some research for those with sbf that you can use the van bracket cause it was used witha saginaw pump if you wanna do that.. I just used the 91 crown vic pump...
I just saw Borgeson has kits to put a saginaw box in 52-64 Full-Sized Ford Cars and 64-70 Mid-Sized Ford, with all the adapters needed. http://www.borgeson.com/xcart/home.php?cat=114
