Hi guys I want to make valve lifter indexer to be available to print on 3d printer but i need the bolt pattern including all hole angle from the marking point so it will be accurate. Does any one may have some info?? I promise the design to be free to download for your own 3d print. I reason i`m doing it is so i can adjust valve without turning the crank at the same time Thank you
