does anyone make new spider gears for the ford banjo rear 1935-48? I can find axles and ring and pinions but my spider gears look like I should replace them, copper showing through. I am putting good parts in the rest of the rear and don't want to put it together just to do it again soon. thanks for any help I am also looking for torque specs for the banjo ring gear and housing bolts
Contact these guys, they specialize in the banjo rears and are real nice guys: http://www.hotrodworks.com/index.asp
Joblot does; www.joblotauto.com. Also, request the full catalog, great reference pics. toll free 1-800-221-0172 e-mail: [email protected] (they do answer e-mail questions unlike some)
I took one of my axles to a differential specialist place in Sacramento and told the guy that I wanted a set of side gears that looked like this! He took one look and said " 7and a half Ford" walked back and sold me a box with the side gears and the spider gears. Only the side gears fit and they were exactly the same with a 28 spline. I had to maching the carrier to fit them but it was not a real problem. I haven't gotten them on the street yet (SOON I hope!) but they were the exact same gear except they had internal splines and a boss on the back side that you need to machine the carrier for. I see you are in Santa Rosa, I live in Fulton, drop me a PM and I will give you the info. I am traveling this week but should be home by Friday and I am sure that I still have the box they came in. Rex
WOW!! I'm gonna have to blow that ol' 7.5 Mustang rear apart now, to see what the side gears look like.
For the record, our axle gears are specifically designed and manufactured to our specifications for this use. (with a substantial investment on our part). They are not off the shelf OEM gears. They are a clone of the 16 tooth Early Ford axle gear, but with 28 splines. Our part number is #1102. They mesh beautifully with the stock early Ford 11 tooth spiders. See them at www.hotrodworks.com Many different gears have been used to perform axle conversions over the last 50 years. Merc, F1, 9", 8" and 7.5" gears. Each has their own problems, but obviously have been made to work. One problem is the hub diameter is so large that after boring the ring gear and differential, the wall thickness of the bearing support is, in our opinion, too thin. We ponied up to make our own gears in order to find the best solution to the early Ford axle conversion problems. Ken
