ford 8BA instead of Teapot
Discussion in 'The Hokey Ass Message Board' started by Jroot, Oct 26, 2013.
  1. Jroot
    Jroot
    from ...Ohio
    Is a Ford 8BA Carburetor and Intake Manifold OK to use on a Mercury 255? The 8BA carb and manifold are all that I have available at this time. If I can use it, will it need to be jetted differently?
    Jroot
  2. uncle max
    uncle max
  3. Rich Wright
    Rich Wright
    There is a social group devoted to the Holley 94 carb. Very easy to set up and make work right. Jets and power valves are the same as for currant Holleys and you can buy rebuild kits from any of the old car sources plus NAPA.
    Accelerator pumps give me more trouble than anything. The old style leather pump seals are the best so if your carb still has one and it's still soft and playable I'd use it.
  4. Ole don
    Ole don
    If you have a 53 four bolt intake, the trick thing to do is enlarge the two big holes to fit a 265 Chev 2GC carb on it. Runs great, gives great fuel mileage.
  5. Weldemup
    Weldemup
    from Central,NY
    Listen to "Ole don".
    A Rochester 2-barrel will run great on the Merc manifold!
  6. Jroot
    Jroot
    from ...Ohio
    49, 50 and 51 mercury used the teapot as far as I know.
  7. Mike51Merc
    Mike51Merc
    WW's were used on a lot of cars. I have a NOS Stromberg WW that I bolted on, just to see if it would fit. The car started right up and drove fairly well, but I swapped it out for dual 48s soon after.
    I'm pretty sure you could tune a WW to work fine on the flathead.
    The '49-'51 Mercs used a Holley 885 which is different than the "teapots" used in Lincolns and later Fords. People call them "backdrafts" or "sidedrafts" but they're really not. They just have an angled airhorn for the side mounted air cleaners of the day. They are pretty good carbs but gained a bad (undeserved) reputation for fires because the float bowl is on top of the carb.
    As for the OP, I think the Ford carb should work fine without any changes.
  8. Jroot
    Jroot
    from ...Ohio
    Thanks for the info. The 94 I have was the stock carb for the 239 it came from. It won't need to be re-jetted for my 255?
  9. Mike51Merc
    Mike51Merc
    I wouldn't re-jet it until you run it, see how it performs, and read the spark plugs.
  10. tubman
    tubman
    Jets may be the same, but the power valves aren't, and can lead to leaks. Also carefully inspect any kit you get, it may be for later 2100/2110's, which can also lead to problems.
  11. Jroot
    Jroot
    from ...Ohio
    Thanks all, so, which power valve should I use for a 255?
  12. birdman1
    birdman1
    the 1949-50-51 used a side-draft carb, not a teapot as I call the 54 and 55 merc 4-barrels. is there a 2-barrell teapot???
  13. jack orchard
    jack orchard
    You might consider adding an adapter to your 3 or 4-bolt manifold and installing an Autolite 2100 or a Motorcraft 2150 carb. 8 different sizes - 190 to 424 CFM... just a thought...jack
  14. dan c
    dan c
    i've had sealing problems using late-model holley power valves, allthough they do fit the 94s. am i doing something wrong?
  15. Mike51Merc
    Mike51Merc
    The late model power valves have a different "shoulder" on the sealing surface.
  16. gibraltar72
    gibraltar72
    from Osseo Mi.
    We called Teapot Towering inferno!
