Finally to the point of mounting the body to the frame. Originally planned on using reproduction wood body blocks mated to the AA frame. After getting the body in its mocked up position (a few inches off from the original locations) it looks like a lot of the blocks would take some serious modification, so am thinking about custom body mounts. The only rubber mounts I could find are some small ones from speedway, but they look pretty small. What have you guys used for mounts for model As. One of the problems is that I would need them to be adjustable or at least be able to be shimmed so that I can line up the door gaps later. Thanks Scott
