Hot Rods Ford 302 bolted to a Lincoln AX4N transaxle
Discussion in 'The Hokey Ass Message Board' started by Gimpdad, Jan 15, 2010.
  1. Gimpdad
    Gimpdad
    from Waco Texas
    I was wondering if my 1957 Ford panel truck could be converted to front wheel drive using my built 302 and a Lincoln AX4N transaxle. This would allow for a lower and flatter floor for wheelchair accessibility.
  2. gimpyshotrods
    gimpyshotrods
    Bolted, no, adapted, maybe. These were a little unreliable until about 1995, or so. Later model ones are electronically shifted, which is another whole can of worms. One from an SHO would likely be strongest, can't remember if those were electronic shift, though. The 302 still might break it.
    Lots of careful measuring would be in order, including if this assembly, when together, will fit between the frame rails. And then there is the issue of suspension...
  3. mustangsix
    mustangsix
    The bellhousing is wrong. You'd need some sort of adapter.
    Why not just the whole 4.6 V8 drivetrain from a FWD Continental? Not sure, but I think it may actually be mounted to a subframe that might be easier to swap.
  4. EagleFreek
    EagleFreek
    from Not Here
    I can't answer your question but I've seen airport shuttle buses that have low floors and I think are front wheel drive using a 4x4 transfer case or maybe a modified case and not connecting a rear shaft to it.
  5. doctorZ
    doctorZ
    correct me if i'm wrong, but wasn't there an SHO ford taurus that came with a transverse mounted 5.0 for front wheel drive? i'm pretty sure i saw one a while back be might be confused. i know little to nothing about sbf's, but won't the 5.0 bolt to everything the 302 does?
  6. gimpyshotrods
    gimpyshotrods
    The SHO only ever had a V6, of Yamaha, Yamaha/Cosworth, and the later Ford designs.
  7. tjm73
    tjm73
    The SHO transmissions were not the same pattern as the 302 bellhousing. The V8 SHO were a whole different engine. Ford never used the 302 in a FWD application that I am aware of.
  8. tjm73
    tjm73
    There were V8 SHO's in 96-99.
  9. gimpyshotrods
    gimpyshotrods
    Shoot, I forgot about those!
  10. 58custom
    58custom
    Yes, a Yamaha V8. Not the SBF.
  11. sloppy_J
    sloppy_J
    yes... 3.4 litre 32v dohc. rated in the neighborhood of 235 hp
  12. 81ttopcoupe
    81ttopcoupe
    from Cedar Park
    And prone to self destruction around 60K miles.
  13. twofosho
    twofosho
    From Wikipedia for what that's worth but my parenthesis;
    '96 up Taurus SHO used a dual overhead cam 4 valve per cylinder 3.4 60 degree V8, same as the Duratec 2.5 V6 (for the Mondeo and Contour among others) with two additional cylinders, and shares that bellhousing (and probably transaxles). Required welding the cams to the swaged on drive gear keep them from slipping and eating valves causing catastrophic failure.
  14. the lincoln fwd sound viable.
  15. doctorZ
    doctorZ
    fair enough and good to know! and here i thought i had something to bring to the table ...
  16. I am also in a wheelchair myself, it just seems to me that there are other ways to do this, and possibly the use of lifts and such to avoid this most-likely extremely costly engineering nightmare! What is your injury? I am a T-3-T-4 Para....... Do you drive from your chair?
    James
