Projects "Fly'nBrian" '34 Roadsterproject.
Discussion in 'Traditional Hot Rods' started by flynbrian48, Apr 28, 2016.
  1. flynbrian48
    flynbrian48
    Did I mention the wheel adapters arrived, and I am geeked about the XKE style wires? Little sporty car radials up front, big tall LT tires out back, yeah baby, no bias plys on this one.
    loudbang, kiwijeff and oldsjoe like this.
  2. oldsjoe
    oldsjoe
    Now the excitement really builds with each step! Joe
  3. flynbrian48
    flynbrian48
    Well, I don't know if it's all that dramatic, but I am excited about it. ;-)
  4. oldsjoe
    oldsjoe
    When the body is on and you make engine sounds sitting behind the wheel it should hit ya. Joe
  5. flynbrian48
    flynbrian48
    It was SO tempting to set the body on yesterday, but, I resisted. ;-) I need to touch up some spots on the tops of the frame rails and horns, run brake lines, rear shock mounts, before that happens. Soon, very soon...
    loudbang and oldsjoe like this.
  6. Limey Kid
    Limey Kid
    Great progress. Like I said earlier, can't wait to see it at Relix!
    Cheers,
    Stewart.
    PS good to put a face to the name at Cobo. Glad to have met you.
  7. flynbrian48
    flynbrian48
    It's up on all four! My buddy Jake helped me with the new kingpin bushings, I painted the spindles today and put the Wilson Welding brakes and Buick drums, and have setting on wheels. I'll pull it back apart to paint and detail the brakes, but it looks pretty good right out of the box, don'cha think?
  8. oldsjoe
    oldsjoe
  9. loudbang
    Yep looks good.
  10. flynbrian48
    flynbrian48
    17203257_10213039499884811_4197733589845737587_n.jpg 17342538_10213039500204819_2372566113471540931_n.jpg 17342837_10213039500364823_4040783924078083394_n.jpg I am extremely happy right now.
  11. OahuEli
    OahuEli
    from Hawaii
    Time for some VROOM VROOM sounds!
  12. oldsjoe
    oldsjoe
    Things are heating up! Looking good Brian! Joe
  13. flynbrian48
    flynbrian48
    This is point where, when building a model car, I'd get glue on the windshield and finger prints in the paint... 17308886_10213075670349050_7401463085174746495_n.jpg
  14. flynbrian48
    flynbrian48
    I haven't had much time lately to work on the '34, but today I squeezed in a couple of hours and managed to re-mount the radiator and grill shell, mock up the hood, align those and drill some new holes in the mount pads. Now, when I take it apart to paint the body and sheet metal, I can (hopefully) put it all back together and have things aligned this well. It's not perfect, but it's pretty darn close. 17523718_10213176088859450_3466695362694935998_n.jpg 17626384_10213176088499441_1502518482958149357_n.jpg
    kiwijeff, 120mm, 36 ROKIT and 6 others like this.
  15. waxhead
    waxhead
    from West Oz
    Alignment looks good to me.
    flynbrian48 likes this.
  16. flynbrian48
    flynbrian48
    17757432_10213205080984235_1940985273489453503_n.jpg 17522890_10213205081264242_9131870707884354827_n.jpg 17634432_10213205160906233_358259999412390150_n.jpg Headlight stands for the '34. These are the F100 shock mounts that came with the pile of parts for the project. Since I don't need them as shock mounts (using Houdaille shocks up front) I bent them out, twisted the upright a little, and welded a tab on the stud for the '37 Chevy headlight bolt to drop onto. I think they 're perfect, although I still have to clock the reflector, lens, and trim ring on the right side headlight to orient the lens the correct way. I'll use Halogen bulbs in new sockets, and a separate blinker/park light bulb as the reflectors already are set up that way. Dig it.
  17. flynbrian48
    flynbrian48
    17757562_10213207746570873_2864557533850458756_n.jpg Splash aprons on! This feature is what I love about a '34 highboy, that graceful swoop of the hood line on the apron the sweeps back below the cowl and to the rear wheel opening.
    kiwijeff, 120mm, koolkemp and 5 others like this.
  18. I feel your pain. Aligning the front sheetmetal on the '33-36 models is a real pain!
    Looks great!
  19. Schwanke Engines
    Schwanke Engines
  20. sloppy jalopies
    sloppy jalopies
  21. flynbrian48
    flynbrian48
    17861698_10213285226827831_7196399856735939171_n.jpg 17903374_10213320404627254_580934509073780050_n.jpg The other day I fitted the w/s posts and chopped frame to the body, after only having them loosely mounted before. It was a challenge getting the posts to fit the cowl and stand at the same angle, requiring some modifications to the original mounting holes, the bracing inside the cowl, and grinding on the bottoms of the bronze posts. It finally fit after several hours of work, but I wondered if I'd now have trouble getting the top irons to fit the w/s posts.
    Today I sat the top on, and "HUZZAH!" the front bow dropped right on the posts, the fit is perfect. Now, I don't like the "loft" of the original bows, the 2nd bow is goofy looking, much too high. The third, or rear bow is fine, the mounts are just dropped in the body 2", but bow #2 has to come down. That means I can't use the weathered Haartz canvas top on the irons, which I really, really like, new canvas will have to be made, and that means the weathered look I want will have to change.
    Well, at least the top irons fit.
  22. Blues4U
    Blues4U
    from So Cal
    Can't that material be "taken in"? BTW, from that angle it doesn't look bad, but then you've got the vision and you know what you want.
  23. Bandit Billy
    Bandit Billy
    That quote and the fact that there is a chain saw in a box lying in front of the car makes me nervous :eek:
    Car is looking great. I have been doing the same fitting up front on my car. Move one thing and everything else takes off, frustrating. Yours is looking great!
  24. flynbrian48
    flynbrian48
    So, after an initial fiasco in which the really narrow front tires I picked wouldn't inflate on the 6" rims, and the chrome flaked off the rim due to the compressed air blast from trying (it would have flaked off driving it anyway, of course that was the ONE wheel I hadn't had out of the box and closely inspected), we have the car up on it's wheels and tires. I ended up going with a modern radial tire, after my experience with the '36, in which the bias ply's didn't handle well, flat spotted, and were generally miserable, we have rubber on the road.
    Or, garage floor.
    23575R15's out back, 16570R15's up front. Nice rubber rake, the front's are a wider than I'd have liked, but they're OK height-wise, and I think with the sheet metal on, and painted, will look fine.
    I'm going to now have to media-blast and pain the rims, as the right front has a big area of missing chrome in the spoke nipples, so they'll probably end up a cream color, which will match the steering wheel and the cream color in the plaid interior fabric. I'll leave them alone until it's all painted and together and then decide, but I like them already, it looks like I'd imagined it, great rubber rake, and the wires look different enough to make me happy.
    I also just got the gas tank, rubber brake lines, and a bunch of other trinket parts to get it together, and will order the black single stage paint soon, so it's moving forward. 18274931_10213501510594790_4918307355235752013_n.jpg 18274902_10213501508154729_1356496336019245577_n.jpg
    chryslerfan55, bct, waxhead and 4 others like this.
  25. flynbrian48
    flynbrian48
    Oh. And the Walker radiator has had the lower hose outlet moved to the right side. So, there's that done too.
  26. ronzmtrwrx
    ronzmtrwrx
    For what it's worth, I like it.
  27. Bandit Billy
    Bandit Billy
    You will be flyin soon Brian, I wish we were closer geographically, be nice to get the cars together and have some fun. You're ahead of me still but I'm trying to catch up. Keep the pedal down, I really enjoy watching your progress.
  28. butchcoat1969
    butchcoat1969
    55 rear Ended??? Back in the day they carried extra ones around with them BC they broke so easy, unless ur gonna run a low hp motor I would use something diff but that's jmo, hotrod harry
    Sent from my iPad using The H.A.M.B. mobile app HotRod Harry
  29. butchcoat1969
    butchcoat1969
    I just gave u my opinion, I'm not saying ur wrong for using it just giving u what has happened and it happened a lot bc they were made on the weak side as far as rear ends go that's why I said unless ur gonna run a low hp engine I didn't mean to get ur hair all raised up over a simple post, sorry for hurting ur feelings hotrod harry
    flynbrian48 and loudbang like this.
  30. Bandit Billy
    Bandit Billy
