Technical Fluid spitting 350.
Discussion in 'The Hokey Ass Message Board' started by TDak, Dec 4, 2017.
  1. TDak
    TDak
    from Oshkosh
    It's a mild 350 in a tri-five that spits black fluid out both exhaust pipes. No smoke. It seems to occur even at idle. Carb is a Holley. Possibly too much carb? Thanks for any ideas.
  2. squirrel
    Sounds normal to me. The black stuff is carbon (soot), the liquid is water. These are normal products of combustion.
    tractorguy, Clay Belt and Hnstray like this.
  3. Deuces
    Deuces
    It's early morning dew....
  4. indyjps
    indyjps
    How do the plugs look?
  5. Model A Gomez
    Model A Gomez
    Like squirrel said it's normal and should quit when the engine gets up to operating temperature. If the inside of the exhaust is black and sotty it is probably running rich.
    rfraze likes this.
  6. TDak
    TDak
    from Oshkosh
    Thanks guys. This happens after warm up as well. Plugs are fouled.
  7. Deuces
    Deuces
    Change the jets to 2 numbers smaller and see if it cures that problem....;)
    Also install a new set of plugs...
  8. Morrisman
    Morrisman
    from England
    Have a look down the carb when it is idling, see if you see fuel dribbling in big drops. I had an Edelbrock that kept doing it, some stupid tiny air hole was blocked. I had reset float level a dozen times, cleaned the snot out of needle valves repeatedly, to no avail.
    Google eventually showed me the problem.
  9. squirrel
    I would do a little more troubleshooting, before changing jets. There are a lot of possibilities that will make a carb run rich, under different conditions. Stock jetting is usually ok, but the float level, choke operation, idle mixture, and (as shown above) simple dirt, can cause problems.
    Hnstray likes this.
  10. TDak
    TDak
    from Oshkosh
    Thanks again everyone.
