Technical Flickering headlights- really dumb question
Discussion in 'The Hokey Ass Message Board' started by Chris, Sep 10, 2020.
  1. clem
    clem
    Just a thought- if you have just put this back together, is there too much paint on your connections, thus not making an adequate connection ?
  2. rusty valley
    rusty valley
    unless i missed it, i have heard heat mentioned yet. usually a bad connection in a component like a dimmer switch will be hot to the touch from the resistance. same with the ground wire.
  3. BamaMav
    BamaMav
    from Berry, AL
    Since you lost high beam altogether, sounds like the dimmer switch has died. All it does is switch the current between the high and low side, it’s probably corroded and melted inside. I had one with similar symptoms as yours one time, first the lights flickered a few times, then I lost both high and low. Mine was the feed wire deteriorated over the years and finally burned in two.
