Flathead water pump Questions!! Speedway?
Discussion in 'The Hokey Ass Message Board' started by Tuck, Sep 26, 2006.
  1. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Who makes the best pumps? Speedway? From there article they look pretty high zoot-
    Can I Rebuild them at home? I have a press- whats the skinny- I've never really had too many problems but my passenger side pump is the equivalent to Niagra falls... and so sign of letting up.
    Tuck
  2. J'st Wandering
    J'st Wandering
    The new pumps are probably all the same. I picked one up from Little Dearborn. Speedway is probably cheaper. I don't know which style you have to rebuild but from my experience, the early car pumps ( 3? to 48) are not worth rebuilding. Have a bushing rather than the larger bearing that the new ones have. The truck pumps can be rebuilt.
    That is what I know and maybe more. Neal
  3. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    huh- the speedway pumps are $89 each. I guess I should order those and have them shipped here quick- I've had pretty good luck with speedway but I'm afraid that when I really NEED something they're gonna get me.
    Tuck
  4. Make sure you get the right width pulley.
  5. Tim
    Tim
    from KCMO
    if they seem like there gona dick around and not get to you on time i can go grab them from there counter and express ship them to ya if you want.
    im all of 5 minutes from there
    tim
  6. jetmek
    jetmek
    the speedway pumps are WAY better than rebuilt origionals...prolly close to 20k miles on mine with no complaints...
  7. Mudslinger
    Mudslinger
    I paid $110 locally. Sounds like a deal.
  8. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    cool after reading this article again in speedways catalog I just ordered two online with the small pullys- I made sure I ordered the right ones.
    I also got a radiator cap from them- should be here by friday-
    Thanks guys-
    Tuck
  9. Bugman
    Bugman
    All that stuff you have laying around and you don't have a spare water pump or two[​IMG]
  10. Flat Ernie
    Flat Ernie
    Tech Editor
    You can get the same pumps as Speedway sells from carquest...not any cheaper, but localy available.
  11. fuel pump
    fuel pump
    from Caro,MI
    I've got the Speedway pumps on my shoebox and they work fine. I'd buy um again.
  12. continentaljohn
    continentaljohn
    Tuck, what year pumps do you need? I have two for the one that goes on the heads NOS that a freind gave me..
    As for the maker of the waterpumps that speedway carries . It's a company in Elgin IL and they sell to most of the vendors out their. I have been trying to get the springs put in there..
  13. cooljerk
    cooljerk
    only problem i found with the new waterpumps, speedway or the others, is that there is no more boss for the heater hose...there are ways around it but still...
  14. Retrorod
    Retrorod
    The nice thing about these pumps with the big bearings is that you don't have to worry about running the belts too tight. The original ones with the bushings didn't like much belt tension, it would tear up the bushings.
  15. Kevin Lee
    Kevin Lee
    Super Moderator
    I have speedway pumps with the correct boss for a heater hose.
  16. cbndrhsr
    cbndrhsr
    from Layton, UT
    We called speedway 3 days ago to order 2 truck pumps (wide pully) They said they were out until Jan '07. So I ordered 2 from C&G and had them in 2 days. They're different than speedway but the're made by Airtex, the company that made them for ford originaly $11O apiece
  17. J'st Wandering
    J'st Wandering
  18. reefer
    reefer
    I bought a pair of pumps from speedway for the french flathead slated to go in the coupe later next year.In the meantime my 21 stud motor `s pumps packed in (leaked like crazy) and I bought a pair of rebuild kits for them.I fit the parts and fitted them to the motor and then greased ¬em....big mistake...I hydrauliced the front of the casing on the first pump right off...my fault..just ignorance.I then bought a pair of "NEW" pumps off Daryl Fryer in California, He makes all new pumps(castings, internals and pullys)in house.They have stainless shafts, improved impellors, sealed roller bearings and ceramic seals.They are a work of art.He insisted that I take the pumps for free!!!fit them and only if I was satisfied, was I to send him payment.He is a true gent and a breath of fresh air in this money mad world...I still cant believe his business practice..but I believe he has shipped all over the world and never had any one cock on him.In fact, even if the pumps were wrong, Id have paid him as he is such a sound guy.
  19. Big Tony
    Big Tony
    I believe 53ASH used speedway pumps on his flattie and it runs cool with no problems even on the hot long ride to the drags last month.
  20. synthsis
    synthsis
    this is all very good info as I'm going to need to do mine sooner or later.
  21. 4dFord/SC
    4dFord/SC
  22. Sweats
    Sweats
    I agree Skip does excellant work and is highly recomended, however if you need them tomorrow Skip aint the guy.
  23. Flathead Youngin'
    Flathead Youngin'
    i debated the speedway vs. skip haney pumps (forbarn really like the haney pumps)....
    i went to the local napa and ordered remans.....my old ones quit leaking....so now they are just laying out there.....:rolleyes:
  24. Jackbolt
    Jackbolt
    I've rebuilt flattie water pumps with kits I ordered from Carpenter's a few years ago. I did a set for a friend and a set for myself and to my knowledge they never did leak. The main problem I ran into was getting the pulleys off without breaking them. I've used up my stock of narrow pulleys.
    By the way Tuck, you're coupe is great looking piece of work, as is all your work. I hope to see it in person someday. I look forward to your posts.
  25. plan9
    plan9
    do you have contact info for Daryl Fryer? is there a website perhaps?
  26. reefer
    reefer
    Yes, I do....M.H.Fryer/Shade Tree Mechanic
    801 W.Bagnall Street.
    Glendora,
    California 91740
    Tel,Daryl Fryer ...626-335-7501
  27. jody165
    jody165
    I used Skip to rebuild these aluminum pumps. I liked the design of his impeller, seems like it would have less turbulence and aeration.
  28. Flathead Youngin'
    Flathead Youngin'
    i've never seen aluminum pumps.....what were those on when new?
  29. jody165
    jody165
    Flatyoungin, these are aftermarket aluminum pumps. But I have seen what I thought was original aluminum pumps. Don't know what they came on or when...where's Bruce Lancaster when you need him....
  30. I was wondering how long it would take before Skip's pumps were mentioned here.
    There's some folks on the Ford Barn that worship his pumps and coils :rolleyes: .
