My question is, Is there any benifit to running oversize valves on my 8BA block? Stock 1.5" vrs chevy type 1.6". Block is at the macine shop and I need to make a decision. I would really like to hear your opinion? Thanks guys
there is probably not a real noticable difference in a street engine, but the chev valves are a good thing I think.you can get nice stainless undercut ones pretty cheap. they are usually a tad longer than originals, so adjustable lifters are needed to fix that. its a cost thing mainly. If your engine has seat inserts already and they are in good condition they should be able to accept being enlarged for the 1.6s easy.
Stock-ish rebuild - no point. Performance rebuild - useful with reground cam 1.6 intake, 1.5 exhaust (chevy) as they're about .100" longer or so. Hi-performance build - the increase in flow is worthwhile and 1.6I/1.6E should be
I put Cheby exhaust valves in a V12 about 25 years ago. Worked slick, the biggest advantage is larger diameter valve stems. You drill under size, then ream to proper clearance. Gives you basically new valve guides.
Thanks Guys, I ordered the tru flow 1.6's from Reds Headers today. A little more money than stock chevy stainless valves but I don't have to worry about the extra length and possibly extra shims under the springs. My machinist is going to install larger seats for these valves also.
