Flathead V-12 Mains Torque limits
Discussion in 'The Hokey Ass Message Board' started by trades707, Jan 22, 2014.
  1. trades707
    trades707
    from Oregon
    What is the proper torque limit for the main bearing nuts on a 48 Flathead V-12? My FOMOCO engine book says 60-70 ft-pounds. Seems like not enough to me. The nuts have wire slots for a hole in the studs, so they won't fall off, but shouldn't the limit be higher?
    Thanks
    Abe
  2. Boryca
    Boryca
    from Detroit
    Go by the book my friend. Always the book. I've got a manual I can cross, but it would probably be similar. I used to think 5/16 threads on con rods were low at 15-20 until I broke one off at 25... the book is solid.
    If you want to cross reference, check SAE torque specs for the size, those are fine thread, 7/16? I think? So 7/16-24?
    Hell, main bolts on a 429 are only torqued to 120... and I think they're 1/2 or 9/16. Apologies on the uncertainty, it's been a minute...
  3. 29AVEE8
    29AVEE8
    Motors Manual says 60-70 Ft. Lbs.
