Technical Flathead T5 hogsheads pics
Discussion in 'The Hokey Ass Message Board' started by Pete, Jan 10, 2018.
  1. Pete
    Pete
    I did a search and couldn’t really find what I was looking for.
    I’m looking for pics and a list of parts needed to mate a T5 to a hogshead. I know folks are doing it but getting a straight answer seems to be difficult.
    Pics??
  2. In my 85 years of life.I have yet to ever hear of a "Hogshead" what you smoking?
    jimmy bruns likes this.
  3. Also called a truck ring.
  4. gimpyshotrods
    gimpyshotrods
  5. 42merc
    42merc
    Dwight Bond in Gibbon Nebraska makes & sells the adapter you need.
    Probably a hundred posts on this set-up a few years ago.
    This is my version of his adapter, only with a Saginaw 3 speed.
  6. gimpyshotrods
    gimpyshotrods
    GM:[​IMG]
    Ford:
    Which T5?
  7. Pete
    Pete
    Ok
    So it’s not just the hogshead but another adapter on top of that?
  8. gimpyshotrods
    gimpyshotrods
    What year flathead do you have, and which T5 (GM or Ford) do you want to put on it?
  9. Mr48chev
    If you have an S-10 T 5 I'd suggest getting the adapter and attending pieces from Dwight Bond. You have to send him a postal money order but he fires the parts back at the same time he cashes the money order.
  10. 40grit
    40grit
    LOL, You have lead a very sheltered life. :)
    I have a hogshead on the shelf in the basement with throw out fork. I am not sure I would be willing to box it up but would sell it if someone in the area needed it.
    John
    Hnstray and seabeecmc like this.
    Yup, you need the hogshead and the Bond adapter plate(for a S10 trans). Works great, I have about 25k miles on this setup in my F-1...
    stillrunners likes this.
  12. 1946caddy
    1946caddy
    from washington
    I've always heard of them being referred to as a truck bell housing or adapter.
  13. Mr48chev
    They are that, I lucked out and my flathead came with one and then the granny four speed that am putting behind the Ford Flathead six in my vintage race car style roadster came with one.
  14. 1946caddy
    1946caddy
    from washington
  15. 1946caddy
    1946caddy
    from washington
    Your never too old to learn something new on the HAMB.
    Tonight I learned what a Scroadster and a Hogshead were.
  16. Say whatever you like but I made a career in the automotive industry..about 50 years of it..
  17. Here's some info
  18. 40grit
    40grit
    Very interesting. I have had this hogshead for years but had never seen the actual technical instructions.
    Thanks for posting.
  19. alchemy
    alchemy
    Rich B, do you need to use the 4-speed front retainer as shown in your PDF? I have a couple hogsheads, but neither came with the 4-speed's retainer. Will a regular old 3-speed retainer fit, or are more mods needed to the adapter then?
  20. 42merc
    42merc
    If you use the Dwight Bond adapter a 3 speed bearing retainer will work. This part accepts the '32-'48 throw-out bearing & return spring. It bolts to the engine side of the adapter & slips over the T5 retainer.
  21. steve hackel
    steve hackel
    So where does one contact "Dwight Bond" to acquire one of these adapters?
  22. rusty valley
    rusty valley
    drive to gibbon nebraska, he owns half the town! or try gibbon body works on google
  23. I have not done this; just had the info saved for future use. I would think there would be a way to make a 3 speed retainer work; just compare it to the hole in the hogshead and see if either a centering ring or a reduction in diameter was needed and then see how it got along with the rest of the stuff.
    Modern Driveline has a similar adapter (MD-401-2114) don't see what they use for a front retainer tho.
  24. Atwater Mike
    Atwater Mike
    You can take the boy away from the hogshead...but you can't take the hogshead away from the boy.
    Wild horses couldn't pry my hogshead from my old wrinkled hands...
    er, wait. That'd be my 'hogs-leg'.
    Things get mixed up like this. Like the pigtail I got for the Mustang...
  25. FORDY 6
    FORDY 6
    This is the Model A / B T-5 adaptor I got from Dwight Bond several years ago...with the peddle shaft & bearings. I had to come up with the rest of the parts...truck hogshead, 20181206_085328.jpg peddles, bushings, etc.
