does anyone know if the adapter is removable. It looks like it comes off. I want a #452 but I want to be able to run my 94's. It claims to be an exact replica, but with a 4 barrel adapter. I can't find any info on it being removable.
are you wanting to run dual 94s? If so i don't think this intake will work for you, you'll need the Offy intake with them spaced apart and will need linkage.
That adaptor removes at the recessed fasteners, taking the manifold down to a pattern meant for early fifties four barrels. I don't see any reasonable use for this manifold for multiple two barrels--you can buy an adaptor to put 2-2's onto there, but that's a pretty Mickey Mouse way to do things when you could buy an actual 2-2 manifold.
