Technical Flathead generator mount
Discussion in 'Traditional Hot Rods' started by Boden, Oct 10, 2019.
  1. coilover
    coilover
    from Texas
    As stated a PCV will take care of venting and you have head bolts, intake bolts, water pump bolts, and even exhaust manifold bolts to mount a fabbed generator mount to. If a 12v system the much smaller newer Delco alternator fits where a generator won't. There is no rule that says one can't drill and tap needed holes in the front of the block or even tig weld something to the intake. 8BA block with 59AB heads picture shows a drilled/tapped hole for the coil mount bracket, a small alternator, and an external point adjustment Chevy distributor. I thought hot rodders were supposed to MAKE parts to solve problems.
    oliver westlund likes this.
  2. lodaddyo
    lodaddyo
    This is what you need to do to run the early intake on an 8ba engine. I ran mine underneath the intake. Its out of sight. 815A70DB-C7D6-4059-9471-35B858EDD9F0.jpeg
  3. coilover
    coilover
    from Texas
    Slick indeed!
    kidcampbell71 likes this.
  4. tubman
    tubman
    While this may work, it's a LOT of "monkey business" that can be avoided by using a proper manifold. They're not that hard to find.
    Flathead Dave likes this.
  5. Boden
    Boden
    That’s what I’m going to do. Use the early style pump stand as a vent
  6. alanp561
    alanp561
    Dammit, now you're trying to complicate things with LOGIC;)
  7. eicke
    eicke
    Any idea what the part number is for this PCV valve?
  8. lodaddyo
    lodaddyo
    BWD PCV-255
    eicke likes this.
  9. Boden
    Boden
    I’m sorry. I’m not farmilliar with PCv valves. What do they do??
  10. tubman
    tubman
    Given this statement, I think it's even more important that you use an 8BA intake.
  11. Petejoe
    Petejoe
    from Zoar, Ohio
  12. Ron Plumlee
    Ron Plumlee
    IMG_2449.jpg IMG_2449.jpg Will try to post pic of what I did.....make a center mount out of 1/4" alum plate and 2" alum angel, then make a mount off to driver side out of flat plate, put an idler on there, done.
    Denns1989 and eicke like this.
  13. Bandit Billy
    Bandit Billy
    Positive Crankcase Ventilation and no ford flathead ever left the factory with one. I was going to say no flathead period but those darn French are just tricky enough to have done so.
    Good idea? Probably.
    Have to have one? Nope.
    Need for ventilation? Certainly.
    Should you research better and heed the opinion of some pretty smart folks on here? By all means!
    Joe Blow likes this.
  14. eicke
    eicke
    Excellent!.....Thanks
