just replaced my head and intake gaskets on 59a no fuel pressure....wont even drip into glass bowl am I forgetting something...done this a few times. thanks guys
nope... rods good and on the arm very good seal, and hard to press when Im pushing the arm when the pumps off
you might of missed the pocket in the fuel pump where the rod sits .other words its in crooked ,not seated properly. hmm,same time post
If it is like the 59A block that I have, the fuel pump rod had an "umbrella type thing' on it that kept the rod straight in the hole.
When was it started last? Some of those babies took a while to get gas up to bowl if the line is empty to tank. I;ve taken air hose with a rag around the filler and give a "little shot "of air to help fuel along,or hand choke the carb til you see fuel comin up....... hope this helps
damn that took awile that time needed primed... but that took real long thanks guys were rolling again
