Technical Flathead flywheel help
Discussion in 'The Hokey Ass Message Board' started by Vanness, Feb 17, 2019.
  1. Vanness
    Vanness
    783D848D-8345-4994-9660-8F83659F9413.jpeg 1448A6E4-F1B9-4899-AC51-1F70FBA5FBF9.jpeg here we go again. Have two flywheels. Both 48-53. One has 11” bolt circle. And one has 10.5 bolt circle. See pics. Both take or look to have had a 10” disc (long). Did they make 10.5”? If so, what application? I know they had 10” and 9.5. Also, I would like to redrill for 9.5 or 10” clutch to not hit on early top loader trans as I bolted up big clutch from truck and it was a no go.
    Thanks as always.
    Anyone near me want to trade for car flywheel with small pattern :)
  2. rusty valley
    rusty valley
    10.5 was the mercury borg &beck type pressure plate. only early trannys have a problem with the bigger pp. if you have a 78 series case all will fit. if you have to drill it, i would go for just a 9"--less rotating weight, and you dont say what your building, but most likely not 400 hp in a truck. 9" is all you need. if you go shopping, the 8ba flywheels have pp bolt holes drilled all the way thru, the 48 on back are not.
    Vanness likes this.
  3. deucendude
    deucendude
    from norcal
    59 flywheels and 8ba flywheels are not interchangeable.
    rusty valley likes this.
  4. rusty valley
    rusty valley
    correct, deucendude, thats why i put the shopping tip in there, but you made it more clear, good for that. i also want to add, what ever size you decide to go with, do not buy the cheapest thing on ebay. buy from ft wayne clutch, american made, balanced, and no further problems after first start up
    Vanness likes this.
  5. 34fordjay
    34fordjay
    from Mass USA
    X2 what rusty valley and deucendude stated
