Technical FLAT HEAD WON'T REV
Discussion in 'The Hokey Ass Message Board' started by gasshole, Sep 30, 2018.
  1. gasshole
    gasshole
    from new jersey
    I just picked up a 1940 Ford that is a older restoration.
    the car idles fine but will barely rev (can hold it wide open in neutral and I don't think it will go high enough to hurt it) . No black smoke or any kind of smoke.
    So far I have blown out the fuel line to tank (new tank)
    Dissembled and cleaned the entire carb.
    Checked that the fuel pump was supplying fuel.
    Filled with fresh fuel.
  2. What carb is on it?
    Is the timing set right?
    What distributor is in it?
    Cam/compression?
    Valve adjustment?
    Timing chain/ base timing ok?
    Have you hooked up a tach or timing/dwell meter to confirm rpm ?
  3. gasshole
    gasshole
    from new jersey
    I have had it for about 2 hrs. it is all stock except the coil that is a modern 6v
    coil. i will say the valves are quite. As for checking the rpm you can hardly drive it so it isn't much. sorry I don't have more answers yet.
  4. oldsman41
    oldsman41
    Check the dizzy make sure it is getting vacuum from the carb also look inside make sure everything is tight and working properly the dizzy will give you fits
  5. flatout51
    flatout51
  6. gasshole
    gasshole
    from new jersey
    I will look into all this tomorrow and update.
  7. landseaandair
    landseaandair
    from phoenix
    If it's not misfiring it could have a restriction in the exhaust. Seen late model vehicles with plugged cats that ran fine but wouldn't rev.
  8. Is the linkage bent? Have someone hold down the gas pedal which you check to see if the butterfly on the carb are all the way open
    Charlie Stephens
  9. Petejoe
    Petejoe
    from Zoar, Ohio
    Also check to see if your choke plate is open and remains open during acceleration.
  10. gasshole
    gasshole
    from new jersey
    Just noticed there is no screen in the fuel pump. Don't know I'd that could be a problem.
  11. GMC BUBBA
    GMC BUBBA
    Bingo, go to napa and buy a rr175 and replace the condensor on the coil adapter. should do it???? Let us know......
    gasshole likes this.
  12. dirty old man
    dirty old man
    I was planning to post about exhaust restriction but you beat me to it.
  13. Boryca
    Boryca
    from Detroit
    I'd go distributor. Vacuum first, condenser second, and timing/points after.
  14. gasshole
    gasshole
    from new jersey
    Ok Bubba I finally got around to trying this and no change. also bypassed the fuel pump with a 6v electric. Still nothing
  15. Petejoe
    Petejoe
    from Zoar, Ohio
    Let’s totally eliminate the fuel system.
    Place a fuel can above the carburetor. Hook up a line directly to your carburetor or attach a hose to a hard line at your inlet.
    I’m thinking carb issues but this will eliminate a blockage that comes and goes or maybe not enough fuel volume.
