Just about to fit the rear hubs back on my 39 after doing the brakes. I need to know what torque to tighten them to. I'm fitting new wheel bearings. Anything special I need to know about. I can't find any info on them. Thought they would at least be on u-tube Thanks. Sent from my SM-T805Y using The H.A.M.B. mobile app
make sure the taper on the axle and in the hub is smooth and almost polished as well as the hub, you want it to go together dry. if you have rough spots, you can smooth them out with emery cloth and lap the hub and axle together with valve lapping compound. it works really well and gets a very tight fit.
