Technical Firewall Insulation
Discussion in 'The Hokey Ass Message Board' started by WisconsinMicko, Jul 19, 2018.
  1. WisconsinMicko
    WisconsinMicko
    from Wisconsin
    What is the BEST firewall insulation for heat reflection? Any and all comments recommendations appreciated. WisconsinMicko
  2. 62rebel
    62rebel
    I'm glad you asked, because I'd like to know myself.
  3. mcsfabrication
    mcsfabrication
    I used Lizard Skin. Front and backside. Sound deadner and heat.
    49ratfink likes this.
  4. BJR
    BJR
    Yea, but how many lizards were harmed to make it?:D
    mgtstumpy, chop job and patmanta like this.
  5. GordonC
    GordonC
    He used 2 - but they were Komodo dragons! LOL!:D
  6. 392
    392
    Rattle trap
  7. Blues4U
    Blues4U
    from So Cal
    I've used Peel & Seal on 2 cars, it works well and is comparatively inexpensive vs the alternatives. Available at Lowe's in different widths, you'll find it in the roofing materials section (it is intended for sealing up roofing seams and ventilation systems.. A single layer works pretty well, but for best heat rejection I'd go with a double layer.
    JeffB2 likes this.
  8. 49ratfink
    49ratfink
    I'm going to use lizard skin. I saw them at a show once where they had a skillet and painted half with Lizard skin and set an ice cube on it and it did not melt. when they put it on the other side it sizzled away in a few seconds. I was sold.
    mgtstumpy likes this.
  9. Latigo
    Latigo
    I used Dynamat. Install was easy. A little spendy but it seems to be the product others compare to so I figured that was a pretty good endorsement.
  10. The peel and stick stuff isn't really a great heat insulator IMO, it starts to melt above 120 degrees. It is a very good sound insulator. Best stuff for heat I've used is a 3/8" thick felt between 2 layers of shiny foil....I used it on my COE engine cover.
    Search the web.....
  11. 29moonshine
    29moonshine
    peel and seal burns good to.
  12. mcsfabrication
    mcsfabrication
    Every lizard was fully melted to be able to spray them on evenly.
    The Lizard skin is a fantastic product, but if you're going to use it, do all the floor area and anywhere else you want to insulate. It's not cheap, but good value.
    I have no skin in the game, just a satisfied customer.
    49ratfink and mgtstumpy like this.
  13. JeffB2
    JeffB2
    from Phoenix,AZ
    I've had Peel N Seal on the inner side of my roof for over five years here in Phoenix with zero issues with summer temps over 115 we are looking for a 118 on Tuesday no melting or smell.
    Blues4U likes this.
  14. That's great to know, thanks. Does it keep your car cooler inside?
  15. You need something thick. I was able to find a factory type pad for my car. It does a good job. If you use something like Dymamat, it should be 1/2" thick.
    RMR&C likes this.
