Projects finally got my long desired 34 3 window
Discussion in 'The Hokey Ass Message Board' started by hotrodderhaag, Jul 19, 2013.
  1. Xman
    Xman
    My 34 3W lid measures the same as Mart's.
  2. daddio211
    daddio211
    You told him it was a '32 5 window, but you didn't mention it was a Chevy, right? :D
    Just teasing ya man. I'm curious to find out where this goes.
    My '27 T Roadster build: www.jalopyjournal.com/forum/showthread.php?t= 734383
  3. hotrodderhaag
    hotrodderhaag
    I gave up on it. The deck lid is sitting in the garage till I dumpster it. I'll have to fix the glass one and make it fit
    Thanks anyways guys
  4. my47buicksuper
    my47buicksuper
    from sunny fl.
    Well I always toyed with buying a glass car and was real iffy on it till i read you post and I must say next time one comes up for sale in my area I might just grab it up and build it
    And you do great work very nice build
  5. hotrodderhaag
    hotrodderhaag
    thank you buick.
    i think alot of guys otta rethink the glass cars.. not saying that they are the best thing to go after. but its a good solution to not having the ability to have that certain steel car that is so desired.
    its been a fun build, i cannot wait to see a coat of paint on it.
  6. There are many fine rides out there made from glass not just repos. I don't have a problem with whatever my ride is made from, It is mine to enjoy as I see fit. Great looking car Ben .Git er dun & on the road.;)
  7. hotrodderhaag
    hotrodderhaag
    Bob
    Hope your roadster makes it home soon.
  8. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    Enjoying your build - I would like to see you figure out where the problem is with the deck lid but I understand that you need to press on.
    Just curious as to what your trunk opening measures compared to others?
    Were/are you planning on louvers in the deck lid ?
  9. redzula
    redzula
    Don't forget to throw the body in the oven too.
  10. hotrodderhaag
    hotrodderhaag
    I started the process of installing the glass deck lid today . I fabbed up some brackets that welded to the structure inside the car. They fit to the seat back area and extend into the truck under the sail panel. Then I pie cut some square tubing to make up the hinge arms. This worked really well and was a lucky guess on the first try to the exact geometry needed to lift the lid at the right angle and clear the body .
    I will have to plasma cut a latch bracket and some hinge attaching plates to replace the temporary ones I made tonight . Then I can glue the skin on. Since I cannot use a steel lid, I'm not louvering anything. I was going to do the deck lid, fuse a roof insert on, and have the hood done. But now I will just leave it all smooth.
    Also today, the more I looked at the front end, it wasn't low enough . So I yanked the front spring and reversed it.i also installed new u bolts and a new clamp base. I like the lower stance now. Gives it a little more rake. I have even considered flattening out the rear crossmember about 2.5-3 inches . Just to give the car the right look .
    Here is a few pics from today
  11. 4 banger 4 life
    4 banger 4 life
    from ohio
    Bad ass very nice ben,,,, u made that car .. Its come such a long ways ...
  12. 3banjos
    3banjos
    from NZ
    Have a look at any after-market or original hinge Ben. They almost curve back on themselves so as to push the lid out slightly before rising, otherwise it will always rub on the top rain gutter. And get the inner hinge mount as high as possible..
  13. hotrodderhaag
    hotrodderhaag
    If I had better pictures, you could see these do the same. It clears the rain gutter by 3/8 of an inch and closes nice and square . They work quite we'll. I order my gasket that slips on the rain gutter. So we will see how it seals then and I'll get the latch in. Then we will be ready to bond the skin on
  14. Shamus
    Shamus
    from NC
    I'm curious about the deck lid dilemma. I'll measure my '33 coupe (Outlaw glass) & '34 roadster (all steel).
    Your coupe is looking great - I admire your skill & determination. You'll be riding soon!!
  15. hotrodderhaag
    hotrodderhaag
    I picked up a top tank for a 34 radiator . This bracket will make installing an aluminum radiator so simple.
  16. hotrodderhaag
    hotrodderhaag
    I ordered a radiator today .Its a custom aluminum one. It should fit nice. I was curious about my engine condition so wanted to inspect it closely .. I pulled the heads again and cleaned it up, it's bored .030 over and looks like it has hardly ever ran, it's so clean inside. It does have a few marks in the cylinder walls, I can't tell if they are scuffs or scratches.. But it looks great. I can see any cracks ether. I oiled all the cylinders up good. I'll wait till the radiator comes and we can start aligning body panels .. That will be fun ....
  17. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    Oh I see, You pawned your 28-36-41-33 buick, chevy, hupmobile, studabaker Deck lid off on me huh?:D:D:D Oh well I will make the damn thing fit, I have a torch and an old welder somewhere around here..:cool::cool: Hell there is atleast an inich of rust that needs cut off that decklid anyhow....LOL
  18. hotrodderhaag
    hotrodderhaag
    HA! thats a good laugh for the day... oooooo its a 34 deck lid for sure. my car is just a misfit stubborn bastard! its alot better than a few others that popped up here on the local swap meet! :)
  19. hotrodderhaag
    hotrodderhaag
    I received my original 34 top radiator tank today with the bracket I needed . So I drilled out the rivets from the back side and heated it with a torch until all the soldering broke free as I could pull the bracket off.
    This bracket will now be mounted to the top tank of my aluminum radiator . Allowing me to put the radiator support rods in the right spot and also to have the grill shell lined up in the proper spot compared to the rods. This will help the painstaking alignment process that is about to come my way
  20. Gary Addcox
    Gary Addcox
    hotrodderhaag, I drive a Brookville '32, but a good friend with a glass '32 always beats me in rod shows because he has a period-correct ride:steelies, pie-crust Firestones, flathead with 3-twos, 39 trans, black paint with half-hood. No one even knows or cares if it's glass. Go for it.
  21. box50
    box50
    Hey dude looking good it's really coming together see ya'll next month.
  22. daddio211
    daddio211
    Wait, you're not suggesting people go to shows to win trophies, ARE YOU!? :rolleyes:
  23. hotrodderhaag
    hotrodderhaag
    I dropped all the glass templates off Friday.. Should have it all back Wednesday !
  24. hotrodderhaag
    hotrodderhaag
    My new radiator came in..
    Looks great . Some modifications to do, but it's aluminum so that's no problem..
    I'm having a hell of a time aligning the hood with the grill and the body..
    It's gonna take some serious time
  25. hotrodderhaag
    hotrodderhaag
    Spring cleaning.
    Window glass is done. I get to pick it up tomorrow. Hoping it all fits well and operates smoothly .
  26. Xman
    Xman
    Thats a Hot Rod for sure!
  27. Flat-Foot
    Flat-Foot
    from Locust NC
  28. hotrodderhaag
    hotrodderhaag
    Meadville plate glass finished up my windows . I took them up some 1/4 thick fiberboard templates, and they returned some perfect size windows with the metal channels installed ready to go. I brought them home and slid them up in the channels and they rolled up like a real car would . Nice and smooth and straight. That abortion came out very nicely! I'm making some bases so when the window rolls down the glass will slide into them and not rattle . Then it's door skin time!!
  29. 4 banger 4 life
    4 banger 4 life
    from ohio
    Hell ya nice work.. Feels good when something goes right for once...
  30. hotrodderhaag
    hotrodderhaag
    This is a pretty big deal to me:
    Still need window crank handles too
