Projects FED with killer Flathead
Discussion in 'The Hokey Ass Message Board' started by fenderless, Nov 16, 2010.
  1. fenderless
    fenderless
    from Norway
    Thanks Tim:) Here are a couple of shots:) Oh I wrote 5200 on the shift, wrong, it was pluss 5000 rpm's:)
    /K
    Taildragger&fenderless 10374094_10154223237440623_4795789971526763850_n.jpg DSC_0730[1].jpg ]
  2. nice slip Kjell 109 in the 1/8 ain't to shabby either
  3. fenderless
    fenderless
    from Norway
    Thanks Carl;) the 109 is Ok, but not so ok with the top speed. I think we can improve :) ?! The tune is well within safe, as it still fat and 27 degrees static on the mag. But something that cofuses me is the MAP????
    /K
  4. fenderless
    fenderless
    from Norway
    Here is the 9. sec run:)
    /K
  5. Kool Kjell, maybe I need the book "Norwegian for Dummies"...........
  6. loudbang
    I think you might want to invest in a new tach. Yours has the needle bouncing all over the place with no relation to engine speed. :p
    But great run never the less.
  7. We actually never watch Tach just run till valves float, then shift huh Kjell.......
    by the way what a beautiful venue to run at!!!!
  8. fenderless
    fenderless
    from Norway
    Yes the tach is not working right:) But I'm a little stubborn, since I really like the Sun Blue-line tach's. I bought tis from the Hamb, and It's a NOS half sweep. I think the ideal solution would be a new bottom on the mag and run a Moroso mech. one. I'll settle for the shiftlight for now. It used to work, but as seen in the video, it flashes up from the start;)
    /K
  9. dragsled
    dragsled
    from Panama IA
    Great Video Kjell , Looks like you had a little tire shake towards the end of the run,,Tim Jones
  10. fenderless
    fenderless
    from Norway
    Thanks Tim:) I was not able to register anything other than the feel og good speed:)
    /K
  11. afaulk
    afaulk
    OK, I didn't understand a word.....I did see some guys having lots of fun! That's a nice sounding flattie. I know you probably posted it earlier but what does your dragster weigh? Cheers, Allan
  12. fenderless
    fenderless
    from Norway
    So you don't understand Norwegian???;) And YES we have a lot of fun, especially the next races at Kjula Dragway:) I don't have the exact weight of the Sidewinder, but around 1280 Lbs:)
    /K
    Taildragger&fenerless
  13. think you better find a scale Kjell you might be surprised.......
  14. fenderless
    fenderless
    from Norway
    Heavier or lighter Carl?;)
    /K
  15. well mine is 130wb no blower and weighs 1356 without my fat ass in there
  16. fenderless
    fenderless
    from Norway
    10371393_674770599225117_8562392802388722563_n.jpg You have probably right Carl;) I'll need to weigh it in. As I'm now hired to a Racing/speed shop, no problem. I might put the Sidewinder on the Dyno too:)
    Oh! We found out why the presssure guage showed 28 psi;) A small backfire when i lifted the throttle at the finnish-line:) Need to put a shim in the Idle bypass valve to make it stiffer. Should solve that:) Got a 20 psi reading at a 10.02 sec run, and that is what we expected:)
    /K
  17. lKool Kjell , what was your speed at 10.02? and what type of stop/check valve do you use for the press gauge?
  18. fenderless
    fenderless
    from Norway
    208 km/t. I think I got the memory-valve from Good Vibrations:)
    Have taken it appart a couple of times for cleaning.
    /K
  19. 10.02 @ 129.24 man thas just what I'm lookin for!!
  20. fenderless
    fenderless
    from Norway
    You will get there with lower boost Carl:) We probably had been there with last years boost of 14-15 psi:) But nooo, we need more power;) I really do't know where 20 psi will get us? but we hope to see low 9 sec ET's:)
    /K
  21. fenderless
    fenderless
    from Norway
    Had a meeting with the guys this evening, and the the plan is layed out for a 9.6 sec run:) 10 days and where off to the first big race at Kjula Raceway;)
    /K
  22. fenderless
    fenderless
    from Norway
    Packed and loaded, not me, just the Sidewinder:) Off tomorrow to Kjula Raceway and hopes to set some New records:)!? Brougt a jug With pops in case:):);)
    /K
  23. go gettum Kjell..........
  24. 38FLATTIE
    38FLATTIE
    from Colorado
    Good luck with the 9.6 run, Kjell!
    We are all waiting to see how you do!
  25. Kustom Dick
    Kustom Dick
    from Finland
    Good luck dude!
    btw, here in Finland we say, when someone throwing up, he speaks norwegian...
  26. fenderless
    fenderless
    from Norway
    Thanks Guys, sorry no New record on the 1320;/ But we got a decent 1/8 mile run. 6.1 sec 113 mph.before the blower snout axle snapped, and no pressure on the last 1/8th mile, rolled over the line for a 10.2 sec ET 90 mph. This weekend had it all, cool roadtrip, Meeting super Nice People, Cold beer, not soo god driving, rain, broke Down. But all in all a good weekend:)
    /K
  27. fenderless
    fenderless
    from Norway
    Just found some video's from this weekend:)
    /K
  28. fenderless
    fenderless
    from Norway
    This one is really good. Shoot this weekend, and already edited and published:)
  29. captmullette
    captmullette
    good video, thanks the second one is killer
  30. fenderless
    fenderless
    from Norway
    Here is a couple of Pictures taken last weekend:)
    Wrinkleling the slicks and lifting the front up:)
    /K[​IMG]
