F100 E brake cable..$30 16 tooth speedo cable..$30 1956 vent window frames with latches..$50pr 1953 Shop manual..$30 battery hold downs..$5ea F100 horn cups with covers..$5ea 1953-1955 Vent window latches..$5ea heater control cables brackets..$10ea turn signal levers..$15 and switch..$35 ignition cylinders and glove box lock-no keys..$20all old heater switches..$15 both F100 firewall wire harness grommet trim..$5 clips for holding wire harness onto frame rail..$15 all battery cutoff switch..$25 vintage old hub cap..$5 760-717-1334
