Projects F.E.D. Build, Y not a Y-Block
Discussion in 'The Hokey Ass Message Board' started by mctim64, Apr 11, 2010.
  1. Toymaker
    Toymaker
    from Fresno,CA
    Tim, to be our guest and follow the "show", guests need to sign in as a customer using a first name only (no other info required), this broadcast is live and UNRECORDED, hope to see everyone Saturday. Rocky
    <!-- / message --><!-- sig -->
  2. My first name, or their first name? :confused:
  3. Toymaker
    Toymaker
    from Fresno,CA
    Their first name, actually I think any name will work:D Rocky
  4. Had a great day at Famoso. This was Elwoods first time to the 1/4 mile and he did very well. I got two runs in the first of which was not the best, when I left the line the front end lifted and I took off towards the "christmas tree" but recovered and made a 11.33 run at 122 mph (reaction time was .002 sec). When we... got back to the pits we checked the air pressure and diameter of the rear tires to see why I veared to the left and sure enough the pressures although close were different as was the tire diameter, with no differential in the rearend when the front came off the ground the larger tire would cover more ground and make the car turn.
    With the tires adjusted we went out for our second run and did much better. Although I red lighted the front lifted as before but went strait. We ran 10.61 @ 124.5 (reaction time was -.194).
    All in all a good day, I got some time in the car and learned a few things. The final gear ratio needs to be changed since both runs had close to the same top speed it's running out before the end of the 1/4, I will go from a 4.33 to a 4.11. Also I need to check bolts for tightness more often as on the second run I got a face full of coolent (water) and found later that one of the foward manifold bolts had come loose. Ooops.
    Here's the video of the first run, a better one is to come that my cousin took, but it needs to be edited. You can see me jump towards the tree. :p
    <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/YbluBfNte7A?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/YbluBfNte7A?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  5. Sounds great Tim, looks like you had a blast.......
  6. Man does that thing ever cook down track! Great video. What are your 60 fters?
    DOn
  7. COOL>>Tim, this is your spare truck engine, right? Does sound great..
  8. NWRacing
    NWRacing
    Love it! My next FED is going to something different, not sure what yet, but different.
    Keep up the good work, car looks great and motor sounds awesome.
  9. Yep!! :p
  10. I'm M18.
  11. Thanks. Very interesting. That is a really nice working piece you have there. Most impressive!
    Don
  12. Damn Tim 002, if you had not tried to take out the light?????............... looking good
  13. Yeah, we'll see if I can match that next spring. You see I red-lighted the next run, but took almost a second off the time. More practice. ;)
  14. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Wow! and i thought your truck was bad ass...Jeez!
  15. My cousin put this video together of me and Elwood on our first trip to Famoso, it's a bit longer than what you are use to but I think he captured the whole thing quite well. Give it a look. ;) You also get to see my second and better run down the 1320.
    <object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/zXeKOgFKk5k?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/zXeKOgFKk5k?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
  16. Cool video, looks like a good day at the races. Nice setup you have put together.
  17. rottenleonard
    rottenleonard
    F-N COOL!!!!
    Aperantly this is your truck engine whats been done to it(stocker-mod?) Just wondering we have been thinking about doing something similar chassis wise, but thinking basicly stock motors to stay on the cheep, but still running low 11's.
    Are you running without a burnout? It seems like I had read that you couldn't do a burnout across the start line ontil you were in a pretty fast ET bracket?
    Thanks Robert
  18. Mart
    Mart
    Enjoyed the vid.
    Cars with a locked rear are a devil to push around a corner ain't they? That brings back memories. I like the y-block rail, I have a couple of y-blocks myself. Really like the pickup- I like em tall and handsome like that. I had a 58 that had been raised back up to stock height after being lowered, I preferred the stock height.
    Tim, enjoyed your flathead and y-block you-tube vids too.
    Mart.
  19. This is my pickup engine but not stock. It's a 338ci (3.875 x 3.575) with a mild very streetable cam. I ran a best of 10.61 @ 124mph but as said in the video a little taller gear will make it run faster and a bit quicker.
    I did do a burnout but since my cousin shot the two before me he didn't turn around fast enough to get it.
  20. OahuEli
    OahuEli
    from Hawaii
    My thoughts exactly when I saw that pic. It scares me to see that p.o.s. on such a sweet motor.
    Edit: Oh, you got rid of it. Whew! I had two different customers' sbc engines fail because of the same problem in a Fram filter. Had to eat the repair bills and I will never use one again.
    Love that Y-block!
  21. As I posted before it was the only "shortie" I could find at the time. It's got a Mobil 1 on it now. ;)
  22. Toymaker
    Toymaker
    from Fresno,CA
    Looking forward to doing it again soon Tim. Rocky
  23. Hot damn what a neat video Tim, now you will need to give me a 6 sec lead. Great editing, gives you a real feel of the day..................Carl
  24. 65COMET
    65COMET
    Tim;it was good to see you and your car at ANRA.I wish I could have got over to talk with you,just got too busy.Great video! I've raced with ANRA since it's rebirth,great group,I hope you get back out to race with us again.I run a 65 Comet in HR class. ROY.
  25. OahuEli
    OahuEli
    from Hawaii
    Good, the Mobil 1 is a much better filter. Just finished watching the video and it looks like a lot of fun! It will be interesting to see what Elwood runs with the "little" motor & 4.11s.
    Keep us posted.
  26. RAY With
    RAY With
    Tim the old Y sounded good on this end.Didnt like the 240 Temp-Hope it's not any thing major. Good luck on your future runs. I am close to finish on the flatty digger here and hope to be out in 2011 race ready for the nostalgia runs. I am getting some parts collected for my Y block also and will probably use it for a back up for the digger.
  27. I keep looking at your Y block and at the FED in my shop with the Jag six sitting in it. I keep thinking if a Y block is that cool for a Ford guy I think I need a 318 poly in that chassis and sell the Jag to a sports car nut (or give it to someone I dont like) See what you started! I have a LA block in the shop which is the same raw casting as a 318 poly. I will measure it in the morning.
    Don
  28. rooman
    rooman
    Don
    The poly heads will bolt on to the LA block but there is an interference problem with the push rods. If you do try to mate them up (it can be done) make sure that you get a cam for a poly as the valve order is different as well. The best thing about the LA is that it is much lighter.
    Roo
  29. I have the same straw hat, my portable EZUP!
  30. Oh I wasnt going to use the LA block.( I just have one here at the moment. ) I would use the real thing. They are the same basic casting and if a LA will fit between the rails so will a Poly. I built the frame rails no wider than necessary for the Jag six. I had for a short moment thought about using 5.7 hemi as i have two of them but it wont go in because of the oil filter housing and oil pump relief casting. My first drag car was a poly (1966.) Maybe my last should be too! I just really like the whole concept of Mctims unit , the way he has done it, how it runs and the whole idea of the vintage V8. Up here 318 polys are only 313 cubes. 313 vrs 312 . It could be fun!
    Don
