If you are talking about the remote control cut outs, I don't think any exist that don't leak and make your ride sound like a POS. they've been selling them for 40 years and have never improved them. They are junk. In this neighborhood they spell it Z A U S T
I was thinking, could you use a pair of old throttle bodies for this? plug the idle air passage thingy and control them with a little lever or something?
[ QUOTE ] I was thinking, could you use a pair of old throttle bodies for this? plug the idle air passage thingy and control them with a little lever or something? [/ QUOTE ] I doubt it. You can't get a seal between the collector flanges without a thick gasket. Ant type of butterfly valve will leak with those temperatures. IMHO
I was wondering about two concentric pipes, one nested in the other with a hole that lines up with the 'loud' pipe when the inner tube is rotated. Just a thought toward a low-tech approach ... Later, papa al
here's some stainless cut outs http://www.pfyc.com/store/merchant.mv?Screen=PROD&Store_Code=PFYC&Product_Code=GN5002&Product_Count=10&Category_Code=GPEXH now they aint cheap either...joe
Try a set from marine store. That's what I got and they work and seal great. I even put power seat screw motors on them and used a power window switch to reverse the polarity.
[ QUOTE ] Try a set from marine store. That's what I got and they work and seal great. I even put power seat screw motors on them and used a power window switch to reverse the polarity. [/ QUOTE ] Bingo...! Expensive new..., search for used or salvaged. Mark
