Technical Engine mounts for Poly 241 Plymouth VS. A or LA engine
Discussion in 'Traditional Hot Rods' started by johnwwjr, Jun 5, 2024.
  1. johnwwjr
    johnwwjr
    Does anyone know if the engine mounts for the 241 poly are similar to/same as, the A engine or hopefully the LA? Heard 318 Poly and 318 LA were the same. Just had an idea and was looking to see.....
  2. foolthrottle
    foolthrottle
    I've used the LA 318 truck mounts on a 331 Chrysler
  3. 73RR
    73RR
    The 241 and most of the 259 and 270 engines do not have side mounts. If you have a side mount block you will find the ears/bolt pattern quite similar to the A-LA.
