sbc 350 .030 over alum. flat top pistons, comp. cam, triple angle valve job,ported intake, and exhauston heads, 307 crankshaft. edelbrock intake, edelbrock 600 carb. the idle rolls. is this the cam? i installed a new stall conv. i filled the trans up today and now its ideling weird. i don't have the vacume module of the trans hooked up yet. could this be why? i have no idea. i just got the motor together and running. all comments welcome.
what is A/F? too much air/fuel tomarow, i'm going to pull the plugs and see what they look like. and i'll back off on the mixture.
so I put my vacume guage on and it says intake leak, or that little place where the auto choke goes. I started the motor and sprayed either at carb gasket, intake gasket, and were the choke went NO leak. I removed the vacume to the dist. and put it on the left vacume side of the carb. now the vacume gauge is steady idle sounds steady. but the V/guage still says vacume leak. the only thing I have disconnected is the vacume module on the trans. but the intake has a plug in it. anyone have any ideas?
