You know some fords require the firing order to change with cam swaps. Also, what octane are you use? But definitly check the valve to piston clearance.
289 1-5-4-2-6-3-7-8 302 (Pre-82) 1-5-4-2-6-3-7-8 5.0 1-5-4-2-6-3-7-8 5.0 HO 1-3-7-2-6-5-4-8 5.0 Truck 1-5-4-2-6-3-7-8 351 1-3-7-2-6-5-4-8
Only a few of my valves were barely touching. Don't know why..but thats what i saw when I pulled the heads.
I will do the straight edge, and examine the valve length, and pushrod length saturday. New rocker and nut will be in hand tomorrow. Still running ok, nut hasn't moved.
