Hello question I have the 56 Buick Century ..I converted from gen. To alternator ..I have an Carter electric pump mounted on the frame rail just in front of the rear wheel. I ran 10 gauge wire negative to negative on battery for ground and pump to toggle switch with a 15 amp fuse between the power source. I have a PUSH BUTTON FOR START Can I run it to the positve side if the coil or battery or fuse box. Thanks
