Have any of you out there used the Delta PAG fans ? Don't want to turn this into a bashing thread, just interested if any have used their fans and how you liked it...or didn't. Thanks Mike
I've installed five of the Delta PAG fans, they moves a lot of air and are quite. You can set the controller to come on and off when you want and if you have two fans you can have them come on and off at different times. Great quality and good guys to work with. If you get one, have them build the shroud for your radiator it will make the fan work the best and your install a lot easier
