Hot Rods Edelbrock C4B, C3B and C3BX
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Dec 7, 2020.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    near as I can tell the C4B with 4 holes was first in 1965, here is a 1967 ad for the C3B and 3 Barrel carb
    1Nimrod, egads and D-Russ like this.
  2. @Moriarity to clarify, the C4B (1965) is earlier than the C3B (1967) based on ads you've found, right? Any idea when the C3BX was introduced, and what the X designates?
    1Nimrod likes this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    I found this 1970ad for the C3BX and it says that the only difference is on the inside of the runners, so the one you posted earlier that I thought may have been an "error" manifold actually is not and is an earlier version of the X manifold than the one I have......
  4. bchctybob
    bchctybob
    My C3BX with the dual carb bolt patterns, the choke pad and without the bulge in the passenger's side. It does have the coil mounting bosses. Sorry about the pics, it's dark in that corner of the shop.
    1Nimrod, Deuces, guthriesmith and 3 others like this.
  5. Fordors
    Fordors
    C05A789B-9BF7-437E-96AD-591BB2011E7C.jpeg There would not have been a C4B if not for Bob Joehnck, he was a lakes racer and all around hot rodder running a garage in LA. He knew both Vic Sr. and Jr., he may have even worked for Sr. at some time.
    Joehnck saw the need for an aluminum 4 barrel SBC manifold and he asked Vic Jr. if they could collaborate and cast some for Bob to sell at his Joehnck Automotive. It took off and Vic soon saw the need to add it to the Edelbrock catalog.
    Photo credit to a member of Corvette Forum
    Deuces, Tim_with_a_T, 1Nimrod and 7 others like this.
  6. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Yes, it does. And, seems it is the “400” special as well...at least according to someone that thought carving that in the manifold was a good idea...:confused:
    Deuces, 1Nimrod, 47chevycoupe and 3 others like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    Here’s a big block version. C396 note the Holley 3 barrel notch in the plenum divider
    enloe, 1Nimrod, D-Russ and 1 other person like this.
  8. blue 49
    blue 49
    from Iowa
    My C3Bx. The swap vender I bought it from warned me a HEI wouldn't fit before I bought it, though I never tried it. My 327 ran very good with this on it.
    Gary
    1Nimrod, Deuces, Richard Head and 3 others like this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    any more C3b , C4b stories?
    1Nimrod likes this.
  10. I had a C3BX but I think I gave it away a few years ago. I did buy a C3B in fair shape and put it on the '41, it does have better low end power over the Offy 360.
  11. 56sedandelivery
    56sedandelivery
    I've had a bunch of these over the years; the one I wished I had kept was the "4-holer" carburetor mounting. Currently, I have a C4b and a C3BX; the C3BX in on a 327, and the C4B is just waiting it's turn at something. Boy, there's a lot of minor differences I never knew about. I am Butch/56sedandelivery.
    Deuces, 1Nimrod, saltracer219 and 3 others like this.
  12. I have seen C4B's and C3B's that have had a notch carved into the rear runner to clear an HEI. I have never tried to run that combination, so I do not know if the notch can be made large enough for an HEI to actually fit.
    Deuces and 1Nimrod like this.
  13. enloe
    enloe
    from east , tn.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    I recently saw an ad for one of these manifolds that had a patch welded over the rear runner where someone ground through it trying to make an HEI fit.... I don't know why anyone would want to run one of those damned ugly things anyhow....
    RICH B, 1Nimrod, Taboo56Chevy and 7 others like this.
  15. Tom65
    Tom65
    Didn't know there were different versions, the Edelbrock Windsor F4b is the most extreme example of different runner lengths.
    Here's my 3BX.
    Now to work out which one Dad had back in the day.
    1Nimrod, Deuces and guthriesmith like this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    Picked up one of the early C3BX manifolds at the swap meet this morning D8973F26-DBBB-4E0C-8484-5738A3FDC077.jpeg
  17. Beanscoot
    Beanscoot
    They must have made an awful lot, of all varieties, of these manifolds...
    Desoto291Hemi likes this.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    I bought a polished one that I assume is a C3B, it has the 3 barrel notch, single Holley only bolt pattern,no holes to mount an ignition coil and the thermostat mounting area is way over on the drivers side, and the fill tube is angled off the other way which is opposite of all the other C3B and C4B and C3BX's that I have, I wonder what the idea was there?
    8764A8E0-19EC-4AD5-A0FE-1A036F0B3DA3.jpeg 1B0D9DBF-ED00-4F5F-B7DB-30B803B43828.jpeg
    1Nimrod, enloe, 1oldtimer and 3 others like this.
  19. lumpy 63
    lumpy 63
    20230924_172904.jpg heres mine with "custom" coil mounting bosses.
  20. That's like mine, I have only seen a few of the pass side oil fill and that's what I needed. All the ones that I saw for sale were out the drivers side. I can't find the other intake but I was wrong on it being a C3BX, it was a C3B and I found pics of it (notice it's a drivers side oil fill).
    1Nimrod and Deuces like this.
  21. DDDenny
    No clue but I know the 64/65 Winters L79 intakes had the oil fill angled toward the passenger side and the 66/67's were angled toward driver side.
  22. bowie
    bowie
    These have always been my “go to” hot rod intakes. Either way passenger fill or driver fill, a great performing manifold : 4A9D1B6F-1AE0-40AC-8FFF-0989248C2F7A.jpeg 881CA0D1-EDCE-455C-8C20-E61C7EA03FC5.jpeg
    1Nimrod, chevy57dude, Deuces and 4 others like this.
  23. bowie
    bowie
    Not quite true to it’s era.. but I’ve always had this C3BX on my coupe: 3074B327-A571-4A30-ABFE-E9888E2C9210.jpeg
    1Nimrod, chevy57dude, Deuces and 5 others like this.
  24. topbubble
    topbubble
    Hey Guys: I have a C4B manifold that does not have the bosses to mount a bracket for a stock sized round coil. What are you all using to mount your coil on this manifold? I'm hoping to avoid mounting my coil on the firewall. Thanks in advance.
  25. hepme
    hepme
    Have a C3B that will take an HEI. Just ground a small amt. off the rear runner so it would turn--works great.
    Deuces likes this.
  26. Is this a decent intake? I have one on my 327 and was thinking of a change, but I’d rather keep it if it’s decent.
    1Nimrod and guthriesmith like this.
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    The L79 intake is fantastic. I surely wouldn’t change it
  28. Tom65
    Tom65
    Bad Chad with a C4B.
  29. enloe
    enloe
    from east , tn.
    I have a C4A manifold. Does anyone have any info on those. I would love to have a L79 intake.
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    C4A?
