1955 Chrysler 300 engine. 3NE55 is the use code. Complete engine except Carbs, air cleaner This should be going back to a restorer but they don't seem interested. $2500 1955 331 Spitfire (poly heads) WE55, old take-out, core, $600 1955 331 Spitfire (poly heads) WE55, old rebuild, with ancient higher-than-stock compression pistons, core, $600 1957 354 Spitfire (poly heads) WE57, old take out, core, $750 VT348, medium duty truck, 331, core, $500 L325, take out, Dodge poly with PF trans still attached, core $800 I also have 'most' of the pieces for a 330 DeSoto; +040 block, crank, heads, rockers, oil pan, front cover, cam..$600 This are just the complete engines. I also have blocks, cranks, heads, and a lot of valve covers including Imperial and Marine. It is time to clean out the shop. No reasonable will be refused so try to be reasonable. A lot of other stuff is listed on my web pages and way too much still needs to be listed. Need a long cross-ram for a B/RB ? $850 Need a Hurst shifter for a 63-65 Dodge/Ply? $400 Weiand 2x4 for 392 $275 and on and on...….. I ship a lot of engines via Fastenal and rates are very fair. I only ship engines enclosed on a pallet whether it is a new rebuild or a core. None damaged so far. This also works well for a pile of random parts. Send an email to: [email protected] or call 541-388-9214
