History Early Ford V-8 Anti-Chatter Rings?
Discussion in 'Traditional Hot Rods' started by David Zivot, Feb 20, 2019.
  1. David Zivot
    David Zivot
    Have any of you early Ford V-8 accessory guys ever seen or heard of
    "Robison Anti-Chatter Rings"?
    Made by Robison Air Jack Co, San Francisco CA, in the 1930's-40's.
    They were stampings, made to clamp around the outer edge of the brake drums,
    supposedly would reduce drum chatter.
    These were applicable to mechanical brakes only up to 1936.
    They were completely unlike the coiled spring-type appliances.
    Any info greatly appreciated. Thank You.
  2. Any chance this is what you are talking about?
    Charlie Stephens
    LOU WELLS likes this.
  3. R Pope
    R Pope
    The coil spring thingies were more for cooling, weren't they?
  4. David Zivot
    David Zivot
    Thanks Charlie Stevens and R Pope...
    No, they are not the reinforcement type steel press-on rings
    that are for Model A drums.
    What I'm referring to are for '32-'36 cast iron drums,
    and have an appearance similar to the lightweight steel securing bands
    that hold the lids on to modern 55 gal plastic drums.
    They are a "C" cross section stamping.
    kidcampbell71 likes this.
