Hot Rods Early altered transmission question
Discussion in 'The Hokey Ass Message Board' started by ididntdoit1960, Nov 23, 2015.
  1. ididntdoit1960
    ididntdoit1960
    from Western MA
    What would an altered from the early 60s have run for a transmission - specifically a B/A - High compression, small displacement (in this case a 283) injected (not supercharged, no nitro) - I wouldn't think a direct drive or a Hydro.....
    volvobrynk likes this.
  2. Mr. Mac
    Mr. Mac
    Probably B&M Hydro
  3. RichFox
    RichFox
    I had a Packard transmission. Side shift. Cool guys had top stick transmissions. But I made a reverse pattern floor shift conversion. Only used 2nd and high anyway. Other guys used Buick or Cad-LaSalle or Ford transmissions. I am sure some used newer stuff or B&M hydro sticks.
    ididntdoit1960 likes this.
  4. ididntdoit1960
    ididntdoit1960
    from Western MA
    was you car center steer (i've seen many early altereds that wern't)? I figured it would prob be a 3sp using 2nd and 3rd.....Just trying to figure out what my car "should" have.......it has a PG now so I feel like the guy with a T5 in his otherwise traditional hot rod.....
  5. AHotRod
    AHotRod
    All of the guys that I have talked to (and I've talked to allot) that Drag Raced a Altered in the mid 50's - early 60's ran a 3 speed manual transmission and launched in 2nd gear. Some used 1st gear depending on the overall combination, low horsepower or higher weight. Many used 4.11 to 4.78 rear gears.... but there were some that even used 3.50 to 3.70. Many told me that due to the fact that the tracks were very poor and scary and the tires were nothing to brag about, it was a balance of tire speed and end-of-track RPM.
    I love mid-50's to early 60's Altereds, I wish we would see more recreated, even as street cars as many were.
    Andamo, volvobrynk and ididntdoit1960 like this.
  6. jseery
    jseery
    from Wichita KS
    I ran a B/A in the mid-60s, 283 with a Chevy three speed. It had center steering and hand operated brakes. All of the similar cars I was around were center steering, hand brakes, rear brakes only, engine set-back, etc.
  7. RichFox
    RichFox
    Mine was not center steer as all the cars I have had since. takes up to much room sitting over the driveshaft. I can have much more headroom with conventional left side steering. See roadster to the upper left
  8. jseery
    jseery
    from Wichita KS
    Might decide what you are wanting to do with it. Street drivable will require some things not required on the track and if you are wanting to race it, it will have to conform to current rules.
  9. ididntdoit1960
    ididntdoit1960
    from Western MA
    Track only - no cooling system etc - set up as a "fun" car to run local "330" drag events and other non sanctioned nostalgia meets - just like you said....98" wheelbase, 42" track width, 25% setback, hand brake on rear only - 2x3 chassis with 1 5/8 roll bar/cage all tig welded....12:1 283, 3.55 open rear
  10. AHotRod
    AHotRod
    How about some pictures of what your building ?
  11. Mad Mouse
    Mad Mouse
    You said you were to run Nitro. You would then be a B/Fuel Altered. We ran one in the late sixties with a 270 Dodge Hemi. Ran direct drive with 4:10 rear end. It ran low Eights at 160 mph. Later we put a slipper clutch ran faster. Lots of fun.
  12. AHotRod
    AHotRod
    Do you have any pictures of it you could share?
  13. ididntdoit1960
    ididntdoit1960
    from Western MA
  14. ididntdoit1960
    ididntdoit1960
    from Western MA
    You must have mis-read my post.....I said No Nitro
  15. Atwater Mike
    Atwater Mike
    Clean purpose-built machine! Very sanitary. I like the pillow block on your extended sector.
    Corvair or Dodge steering box? (looks Corvair?)
  16. ididntdoit1960
    ididntdoit1960
    from Western MA
    Thanks - I'm big on less is more - its a reversed corvair box with a kit from gas alley for the side steer - I made the brackets and gussets to mount it and bought the pillow block at a local bearing supply house - the gas alley kit was good, but I did need to turn down the shaft a bit as it was oversize - the support bearing they tell you to buy from speedway was a joke.
  17. AHotRod
    AHotRod
    I agree.
    The Bantam looks "Spot-On" !
    I think you should leave the glide in it .... you already have it, why speed more money on old transmissions, clutches,flywheels,scattershield, starter,shifter.
    It will be a hoot to drive !!!
    By the way, whose slicks are on it?
  18. AHotRod
    AHotRod
    I think this one is very cool.
    How are you going to do your headers?
  19. ididntdoit1960
    ididntdoit1960
    from Western MA
    Its gonna stay.....at least for now - its just great to ask a question here and get accurate answers from people that were there and doing it......with pictures too! I was curious as to what "belonged" in there - the slicks are towel city - would I be allowed to run this thing at the meltdown? I cant imagine it will be that fast, but would they still require a current spec full cage? Still a lot of work to do between now and then - the firewall is next
  20. ididntdoit1960
    ididntdoit1960
    from Western MA
    Im thinking very short up-turned small diameter (1.5" od) zoomies - that way they will clear the steering link on the outside of the frame (not installed yet) - but we'll see once I get there
  21. AHotRod
    AHotRod
    The majority of the Altereds back then ran 4 individual pipes .... from very short to very long.
    I have lot's of pictures if you need examples.
    Here are a few....
  22. RichFox
    RichFox
    Austin.JPG How it was at my house. Started in 59. Went in the Army. Got it running in late 63. Zoomies had not been invented yet.
  23. flatheadgary
    flatheadgary
    from boron,ca
    love your bantam!! it looks like mine i built in '94, except mine is flathead powered and a late spec cage with a c4 trans.. i have been harping at people for over 20 years to build altereds, as they are the fastest cars on the least amount of money. that is if you don't let everybody tell you you have to have all the latest high dollar stuff on it. i.e., chrome and billet, electronics, expensive wheels and tires. i ran street radials on mine for over 3 years before i put slicks on it. to give you an idea on cost, i built mine for $2500 back in '94..don't think you wont win any either. i run in a series 5 times a year against 10 second altereds and dragsters and have won more and been in the semi's and finals than anyone else.
    AHotRod likes this.
  24. Very cool altered. Run the powerglide and see how she does, should be all kinds of fun, and maybe faster then you think!
  25. pnevells
    pnevells
    Run a powerglide and have fun racing your car, the chevy three speeds leaving in second was because there was nothing else, and it was easy to make them flat shift fast. We have a glide in our car and it is a blast to drive and still looks the part of a 60's altered
