Getting ready to remove the front springs on my 52 Olds to cut off a coil. This lever-shock front suspension is unfamiliar to me. I 'm thinking the usual floor jack under the lower a-arm after putting the car on jackstands, then removing the upper trunnion bolt. Is that a two piece bolt? Slowly lower the floor jack to release the spring? Yeah, I know, carefully. Do I need to unbolt the stabilizer bar too? (probably) I know a lot of you guys have done this. Any tips? Thanks, Tom
Is Chevy done the same as Oldsmobile? Doesn't look the same, as Chevy has tubular shocks and I have the lever action which is part of the upper control arm. Tom
oops sorry, I completely missed that you said Olds! Should be similar to the earlier Chevys, 39-48 models. http://chevy.oldcarmanualproject.com/shop/1942_47/index.htm Although it would probably be a good idea for you to find an old used shop manual for your car, they probably are available on ebay.
Thanks Squirrel. That does appear similar. Seems like they suggest a funky way of doing it by supporting the lower a-frame and then raising the car with a chain hoist. (unavailable) I bet I can raise the car up and support it and then lower the jack for the same effect. Thanks, Tom
I would do it like you suggested in your first post except remove the lower trunnion bolt instead. The upper controls all the alignment settings and even though it should be aligned afterward at least you won't lose your original settings. I'm sure the service manual shows removing the inner pivot on the lower A frame because that would make it easier to get the spring in the pockets but I'm sure you'll be fine the other way, sounds like maybe you've done it that way already with regular ball joint suspension.
Thanks for the info. Yes, that's the way I've done it with regular ball joints. Hopefully, I can find someone who knows how to line the thing up afterwards. Bet not many have worked on something like that before. Tom
Taking the lower trunion out is how I did my '50 Olds but I used internal coil spring compressors since I was down to bare frame and didn't have any weight to keep the spring under control. Right know the alignment is by "eyeball" with too much caster on one side.
Didn't cut coils but replaced all the moving suspension parts and put in Fatman 2-1/2" dropped spindles. The rear on 49-50 is coil spring and used 3" dropped springs there. That's 3" from new stock and it needs to go lower by an inch or so.
