What on earth do you guys use or do lol. Can't seem to figure out room where to mount a shock that won't hit the tire or tie rod?
mine is a 54 and the shock is behind the A arm and it does not hit, but I see you have the steering box back there. mount the lower part of the shock to the top of the bottom A arm, that will pull it in an inch or 2.
Hmmmm... no. I crack me up. Most of the shocks I see are mounted that way, I see a lot of shocks. Especially the stem mounting styles. Now gas shocks can be mounted upside down, which is what you are suggesting. But older oil filled shocks shouldn't be.
