Projects Eagle cast cranks any good?
Discussion in 'The Hokey Ass Message Board' started by 31hotrodguy, May 26, 2020.
  1. 31hotrodguy
    31hotrodguy
    So I’m looking at a Eagle stroker crank from Butler performance for my Pontiac and I wondering if anyone had had any experience with them good or bad? The price is good but sometimes you get what you pay also! Adjustments.JPG
    dana barlow likes this.
  2. jimmy six
    jimmy six
    I’m sure they would meet someone’s specs. I prefer SCAT to Eagle. If it’s a stocker/cruiser you probably can’t go wrong as long as it’s a reputable dealer you could return after you check it out. We used one Eagle steel in a dirt track engine and it was perfect. Sold it to get more stroke..
    mgtstumpy, loudbang and 31hotrodguy like this.
  3. AngleDrive
    AngleDrive
    from Florida
  4. southcross2631
    southcross2631
    Ran an Eagle crank and rods in my old Plymouth Gasser. It was forged ,but I put over 500 passes on it with no bearing wear.
    eagle cranks are just a little rougher looking than a Scat but their cast cranks work well. I have installed a bunch of them in 383 Chevy builds. They seem to balance out well.
    Butler sells good stuff and they should stand behind anything they sell.
    Baumi, loudbang and 31hotrodguy like this.
  5. sdluck
    sdluck
    Butler has a pretty good reputation .
  6. MAD MIKE
    MAD MIKE
    from 94577
    Cast steel is fine for street use and the occasional drag racing.
    But if you plan on beating on it or doing any kind of open track events, extended high load/rpm pulls, then I would suggest you opt for the forged steel.
  7. 31hotrodguy
    31hotrodguy
    Thank you! That helps. It’s for the 60 Catalina. It is street car but I do plan on running it. You all answered my question. Thanks
  8. DDDenny
    Callies for me.
    1934coupe likes this.
  9. 31hotrodguy
    31hotrodguy
    I did not find a listing for a Pontic crank on Callies website. But yes they are nice. I have a dragon slayer 350 Chevy crank and it is very nice!
  10. Phil1934
    Phil1934
    You planning on running that through a Jetway or expensive TH adapter? I so, look for a later model 455. If it's a stick, never mind.
    31hotrodguy likes this.
  11. 31hotrodguy
    31hotrodguy
  12. sunbeam
    sunbeam
    Early eagle cranks were not balanced very well. A 383 Chevy crank A got required Mallory to balance.
  13. 31hotrodguy
    31hotrodguy
    And Mallory ant cheap. I had heard that before which was one of my reasons for posting but it looks like they are better now.
  14. badvolvo
    badvolvo
    Eagle / Skat debate. My machinist says, they are about the same. He has had better luck with balancing the Eagle on big " big blocks. I have a skat cast steel in my 377" sbc, it's drag raced and sees 6500 on every pass. No issues and balanced well. I went with the eagle forged on my 632" bbc, again, balanced well and no issues, it sees 7000+.
    I got a call from said machinist yesterday, a guy I sold a car to, brought the engine in for rebuild after blowing it up with NOS. The 406" was built over 20 years ago, with a stock crankshaft. It lived 20+ years making close to 600 hp. The stock crankshaft was still within spec. This time they are building it for NOS. Just pointing out that stock crankshaft held up extremely well, considering 7000 rpm and 20 years of abuse. It is getting upgraded this time.
  15. 31hotrodguy
    31hotrodguy
    That is a pretty good “track record!” [emoji6]
    badvolvo likes this.
  16. lostone
    lostone
    from kansas
    Yeah with butler's reputation if he sells it on their site I'd have no problem running it.
    If its something I was going to beat on a bit in that heavy car I'd call butler and ask their advice.
    Did that with a Pontiac 428 and Bill Miller aluminum rods, wanted to know how safe for the street and rpm limit.
    Called asked the questions, got my answers. Told me no problem on the street and pontiac heads couldn't breath high enuff to hurt their rods. I asked if that was guaranteed and he laughed and said " I'm Bill Miller and this is my company, if you hurt my rods, send em back and I'll buy you a whole new motor", i ordered the rods right there.
    Budget36 likes this.
