I know after all these years I should know this but sometimes a guy forgets. On a drum drum setup is the front for the front and rear for the rear on the master or vice versa? Thanks, Tony.
In the original mounting posistion yes. Most drum/drum master cylinders it won't matter anyway. As soon as I have said that though, some one will come up with a multi stage bore as an example.
This master is supposedly for a 67 chevelle with non power 4 wheel drums. I had it mounted under the floor of my 53 poncho and now I'm moving it to the firewall. Since I need to do Some rework on the lines I figure I might as well make sure its right before i break out the benders and flare tools.
