  1. 65pacecar
    65pacecar
    from KY, AZ
  2. 65pacecar
    65pacecar
    from KY, AZ
  3. Speed Gems
    Speed Gems
    deadbeat, Offset and 65pacecar like this.
  4. Speed Gems
    Speed Gems
  5. 65pacecar likes this.
  6. 0ldracer
    0ldracer
  7. deadbeat
    deadbeat
    Some great stuff on here tonight, to all who post, thank you for all the input.
    But now I cant get that theme song out of my head,, cheers
  8. noboD
    noboD
    You could always replace it with " Once upon a time in the West?" with Claudia Cardinale.
  9. Marty Strode
    Marty Strode
    From the pistons, it looks like it was a Hemi at one time !
  10. Jimbo17
    Jimbo17
  11. old flopper
    old flopper
    30 mins earlier the conversation was; “let’s just tilt the can and run 100% nitro, what could possibly go wrong with cross bolted mains.”
    deadbeat and 65pacecar like this.
  12. bchctybob
    bchctybob
    I think I read somewhere that it started out as a Bandini sports car? What made me remember is, when I was growing up, Bandini was a brand of fertilizer my Dad used. Lol
    65pacecar, chryslerfan55 and Fordors like this.
  13. Roland and Mike Snively...
  14. 65pacecar
    65pacecar
    from KY, AZ
  15. tommyd
    tommyd
    from South Indy
    METAL MELTDOWN likes this.
  16. 6sally6
    6sally6
  17. patsurf
    patsurf
    ..........Liking the Chick in the hat!!! (gotta be 60's-early 70's!)
    [​IMG][/QUOTE]
    the other one looks like a harder worker though....
  18. jnaki
    jnaki
    “In discussing this with Gene recently, he verified it was correct, including the two manhole covers bolted in the trunk. One discrepancy in the Nats coverage in the Nov. ’57 issue says the car weighed 3700 lbs. While the Engle Ad in that issue says 4150 lbs. The latter is probably correct because the car had to make C/Gas weight, since the blower bumped it up one class.”
    From Pat Ganahl’s story on Gene Adams
    “Don’t know where the 2-port Hilborn injector is. Do you suppose the manhole covers are under those towels? Neat, tidy, orderly–that’s the way Gene has always done things.”
    Hello,
    We learned many tricks for adjusting the traction and weight distribution from early drag racers. By the time we were ready to make the move to C/Gas with our 1940 Willys Coupe, the rules were established and no alternative was allowed, unless it was a part of the structure of the car.
    So, my brother and I put in some 1 inch steel plates from a local scrap yard into the trunk of our 40 Willys Coupe. The weight was heavy enough and placed correctly to not move on acceleration. They were on the trunk floor, giving needed weight over the rear end and slicks. But, upon tech inspection at Lion’s Dragstrip, we were told that the non-secured steel plates were illegal as they were just additions and not a part of the car. Like adding sand bags, bar bells, etc.
    We cut and moved the plates above the rear axle, welded them into place. The remaining plates were welded to the steel structure of the trunk over the gas tank. Now, when we went back to the Lion’s Dragstrip tech inspection line, they approved the installation and it was part of the rigid structure and support of the rear trunk area of the Willys Coupe. I suppose we could have welded in vertical steel plates to line the trunk for more weight, but, what we welded in place was sufficient to get us into the C/Gas class.
    Jnaki
    Now, the larger 283 bored out to 292 c.i. and the addition of the new Isky Gilmer Belt Drive 671 Supercharger, plus blower spec parts made the final package potent enough to do some eliminating and gather wins in the class.
    Similar set up with 6 Stromberg Carbs on an Isky Gilmer Belt Drive for a 671 on a SBC motor. Also, the 2.5 gallon Moon Aluminum Gas Tank and Pump was attached to the floor in front of the passenger bucket seat in our 1940 Willys Coupe, too.
    Drag Cars in Motion
  19. Speed Gems
    Speed Gems
  20. Speed Gems
    Speed Gems
  21. Speed Gems
    Speed Gems
  22. Speed Gems
    Speed Gems
  23. Speed Gems
    Speed Gems
  24. 65pacecar
    65pacecar
    from KY, AZ
    RIP Gordon Collett
  25. Deuces, deadbeat and Speed Gems like this.
  26. 65pacecar
    65pacecar
    from KY, AZ
