Technical Doors filled after chop?
Discussion in 'Traditional Customs' started by Xtent, Jul 19, 2019.
  1. Xtent
    Xtent
    from Santee
    I am interested in a car, my big issue is the doors were filled, so no side windows.
    The car is 10k, if is is possible to get side windows put on via new doors needed, what would be a ballpark number for that.
    Just want to see if it would cost more than the car to get done.
  2. I'm no help but what kind of car? It would be a vast range between replacing doors on a true hartop with no frames or chopping doors to fit the car or even more work/cost to have windows fitted if the window frames were eliminated.
    chryslerfan55 and williebill like this.
  3. AChopped1950ford
    AChopped1950ford
    Can we see photos of the car ?
  4. Xtent
    Xtent
    from Santee
    When I get back to my PC, will upload.
    The car is a 47 Plymouth.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    was it a 4 door and the rear doors were filled? I don't understand.....
  6. Xtent
    Xtent
    from Santee
    It was a coupe
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    so the quarter windows are filled then?
  8. @Moriarity I think he's talking about the window slots being filled over.... like was done on the Fancy Pants Riv. It had no side windows.
    chryslerfan55 and Moriarity like this.
  9. Are the upper door window frames still there? Or was it "hardtopped" when it was chopped?
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I understand now.....
  11. Xtent
    Xtent
    from Santee
    Will verify the upper window frames
  12. It's been hardtopped. The door window frames were eliminated as well as the B-pillar. I'm not saying it can't be done but it would be some work to put windows back on it.
    One option would be have channels made and put glass back in the existing doors and slide in quarter windows, Matranga Mercury style.
  13. gschwen
    gschwen
    from Hemet
    Assuming it's this one on Craig's list?
    Unless the window regulators are still in the door, and you can get the window frames and missing b-piller parts from the owner still, or can source them from somewhere else, that's going to be super difficult to do.
  14. 49ratfink
    49ratfink
    wow. that car looks like ass. why would someone do that?
    assuming you had a door and a roof from a donor car you are probably looking at 100 hours of labor plus paint.
    chryslerfan55 and kidcampbell71 like this.
  15. Looks like rear end could go back a couple of inches.
  16. williebill
    williebill
    You need the door tops and side window pieces, and keep it a hardtop, but the right way. Door tops get welded into the roof. That's one solution.
    I was thinking High School Confidential from your first post.
  17. Corn Fed
    Corn Fed
    Save your money. Even without the body being screwed up, very few 47 Plymouths will ever be worth North of $10K. Especially as time marches on.
  18. Jalopy Joker
    Jalopy Joker
    Yikes!! walk away
  19. Kiwi 4d
    Kiwi 4d
    In my opinion ,if this is the car above and you want windows (should have windows anyway) I think you need to walk away unfortunately. Way more work and bother than its worth to fit working windows .
  20. Kiwi 4d
    Kiwi 4d
    This 41 de Soto is for sale on here now, I know it a major project but a rare and cool car plus its pre 48. You can see what you are getting. Even the floors might be decent as it still has glass. Someone needs to take up the challenge.
  21. Xtent
    Xtent
    from Santee
    Thank you guys for the input, that is the car I was interested in.
    Going to pass on it and wait for something else to pop up.
  22. 19Fordy
    19Fordy
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    I looked at the CL ad, that really looked like a thrown together piece of junk. you saved yourself a lot of heartache by not buying it
  24. punkabilly1306
    punkabilly1306
    from ohio
    Trust me when I say this...usually filled in glass is the sign that a bad chop took place and the builder realized it and knew the windows wouldn’t work right. Unlike you, I bought the POS I was looking at ‍♂️
