has anyone attempted to do there own seats in an roll and pleated style. if so how did you do it. edges and fitting material together etc. also any photo shots
If you go to the Upholstery Social group,there are some threads there showing you what you need to know,,,
Go to the group like was said. You can buy the material already pleated, but they are heat seams, not stitched. I did sew my own. You start with the special foam, called sewfoam, which is foam with cloth glued to the back side. You need that cloth for 2 reasons; one is so the threads won't cut/ and pull right through the foam, and also the cloth backing helps the gripper pull the material through while sewing. The thicker the foam, the better the machine needs to be. Think of it as like trying to sew through a pillow. The "foot" of the machine needs to climb up over, and not dig into the vinyl. Unpleated Vinyl can be bought at Jo-ann's stores. Ask for marine vinyl. They do not have sewfoam. They do have 1/2" and thicker foam, but you'd need to spray glue some cloth to it, to make sewfoam.
Search in the Upholstery social group for a tech piece that gilgonzales did he does a step by step on one way to do it.
