does my model a look bad ??????
Discussion in 'The Hokey Ass Message Board' started by Slag Kustom, May 18, 2004.
  1. Slag Kustom
    Slag Kustom
    some times in doing my own work with too many options in my head i start to get lost and not like any of the work i have done . I need some thoughts on what i have done so far
    it's a 1931 model a pickup chopped 4.5" sectioned 2" channeled 3" cab streched 4" suicide flush fit doors 1957 ford dash . im not sure if i want to keep the fire wall i made. i am not that fond of it but i refuse to use a flat one with a dimple for the magneto. or one of those store bought gerneric recesed ones that has no chance of fitting with out cutting it up to ribbons help me out with your thoughts
  2. Slag Kustom
    Slag Kustom
    pic above is 00 mack pointing at his 1 minute stripe job to make me like the fire wall
  3. Slag Kustom
    Slag Kustom
    1957 ford dash cut 6 ways to sunday to fit
  4. Slag Kustom
    Slag Kustom
  5. Slag Kustom
    Slag Kustom
  6. Slag Kustom
    Slag Kustom
    bottom of doors and cab corner finished flush with the bottom of the frame
  7. G V Gordon
    G V Gordon
    from Enid OK
    My two cents... I like the firewall and I think you will too once it is smoothed up and painted, or at least primed so it blends with the rest of the car. Oh, and YOU BUILT IT!
  8. Slag Kustom
    Slag Kustom
    do the head light look too big ?????? im going to run a chopped 32 steel shell
  9. cleatus
    cleatus
    from Sacramento
    Not bad at all, I kinda like the coffin shape in the firewall. The cab stretch and lights look good too.
    Is the smoke in the cab stretch picture coming from the exhaust or your bong?
  10. spudshaft
    spudshaft
    I think the firewall is going to look fine. You might want to put the valve covers back on before you start welding/grinding/bondo-ing to keep crap out of there.
    Also, I think you may want a different exhaust. Those kind of look t-bucketish.
  11. Slag Kustom
    Slag Kustom
    the exhaust was a freebee from a friends t bucket i re did for him im thinking of cutting it up and using the big radius bend to make some style of low lakester headers that will follow the bottom of the body but again i cant decide
  12. DrJ
    DrJ
    I'm kinda wondering about that British cable winch? on the front end.... [​IMG] [​IMG]
  13. 296 V8
    296 V8
    from Nor~Cal
    Dig that Jag front bumper [​IMG] Looks good. like cross rams alot.
  14. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    <font color="green">Looks good.
    What the hell is that seat out of and when is it gonna be out of that car? [​IMG]
    Low backs man, low backs.
    RASHY </font>
  15. 30roadster
    30roadster
    for NOT deciding i'd say your making good decisions [​IMG] ...looks great to me!
  16. Slag Kustom
    Slag Kustom
    not sure what to do with it. thats why there is no mention of it. but i have to say i am thinking about it for the fact that i can run the bed lower on the frame and have the full size bed with plenty of travel. i would hate to build a pickup with a bed that can not be used for more then a moon tank holder and a place to put the battery and a six pack. i need room for a keg (full of beer) and the junk i buy at the swap meet
  17. Slag Kustom
    Slag Kustom
    seats are a $20 purchase at a swap meet that are now mounted to what was my office chair
  18. BigDdy31
    BigDdy31
    I like it so far. A lot of hard work in it. I too think the firewall will look good once it's finished off. But when it's your own work it can be kinda hard to get a good perspective.
    You may be right. The headlights might be a bit big. But I would wait on that decision until you have more of the structure finished off and can see the proportions better.
    Big Daddy Eric
  19. Slag Kustom
    Slag Kustom
    i have another cross ram i may use instead of that one that uses 6 rochester 2gc carbs but again im not sure yet
  20. Smokin Joe
    Smokin Joe
    Local 4X4 club help you build that front suspension?
    Just kidding, looks like you used a Jag rear in the front! [​IMG]
    From the pics it's hard to see what you have going on up there. The firewall is fine. Any issues with the valve covers whn the engine rocks? It looks close on the corners. I'd make a set of headers for it and run the pipes closer to the body. Sell the ones you have to someone building a T bucket. Put plugs on the light wires so you can swap them out with a different style when your mood changes. How does the car fit you? Could you do some miles in it or will you have a crooked neck after 10 minutes. That's priority #1. You won't drive it if it isn't comfortable no matter how cool it looks.
  21. Slag Kustom
    Slag Kustom
    the front end is a 4" beam with split bones and f-100 box the big pile in front of the car is a jag rear that im not sure about
  22. KCsledz
    KCsledz
    Its looking good. How bout streatching the headlights like you streached the cab.
    Just my 2 cents.
  23. Django
    Django
    from Chicago
    That's going to be cool when you get it on the road. I think I know why you don't like the firewall. The left side does not match the right side. If the pass was the same as the driver's side, it would look better I think. As for your headlights, they need to be mounted so they hang straight. Right now it looks like you are using the mounts as they came off the donor car and they are angling the lights outword, which does not look right at all. I think the size will be ok, and they will look better visually with the deuce grill... they just have to be straight. I really like the bottom frame/cab and the extended doors. I have to agree on the seats... high backs gotta go.
    EDIT:, I looked at the firewall again, and maybe it's just the pic that makes it look uneven. What exactly don't you like about it?
  24. haring
    haring
    I had the same questions as everyone else -- what the heck is all the metal up front, but you answered the question. You need to roll that puppy out into the clear to get some real photos so we can actually see it (without Jag rearends blocking the view)!
    Just pick a theme and stick to it and you'll be fine.
  25. 00 MACK
    00 MACK
    as a few of you may know,I know this guy pretty well.As much as Im always harping on period correct hardware blah,blah blah ,The thing about this guy is that he aint in it for the costume party or the little kulture scene.All he gives a shit about is CUTTING,WELDING,CUTTING SOME MORE AND ARROW STRAIGHT BODYWORK.Then he proceeds to beat the everloing shit out of em when they are done. This guy is form following function which is why he will probably never completely subscribe to any particular theme when building anything. I know that he plans on abusing this car so bad that he even installed power wiper to beat it in the rain
  26. Fat Hack
    Fat Hack
    from Detroit
    Off to a damn good start...doesn't look like a generic "rat rod" or anything stupid.
    It's got enough owner built "cool" to stand out from the slap together junk getting so popular now.
    Just keep at it and do what YOU dig...it'll be a sweet streeter when you're done!
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  27. Shoeboxer
    Shoeboxer
    I'm digging it! I can totally see the potential there and all the work you've put into it so far. [​IMG] It's gonna look great when it's done!
    -Taylor
  28. Slag Kustom
    Slag Kustom
    who are you fuking kidding anthony i plan on towing it behind your merc to car shows and putting velvet ropes around it as i display all the trophys i have won. I will stand around wiping it with a diaper to keep the dust off it
  29. AKATIREGUY
    AKATIREGUY
    WHATS THE LOOK WE STARTED WITH??? RAT ROD OR IS THIS GONNA GET SOME SHINEY COLOR. FIREWALL LOOKS BITCHEN FOR THE RAT ROD STYLE IT LOOKS LIKE YOUR GOING FOR.
    AS FOR THOSE PIPES... HACK THE DAMN THINGS A FOOT OFF THE MANIFOLD AND BEND THEM BACK... YOU CAN ALWAYS THROW INSERTS IN EM IF YOU CANT HEAR YOURSELF THINK.. BUT IF YOUR LIKE ME, HEARING YOURSELF THINK IS NOT ALWAYS A GOOD THING..
  30. Slag Kustom
    Slag Kustom
    it is going to get somke kind of paint as of right now im thinking tangerine candy over silver metal flake and anthony (00MACK) owes me 2 cans worth of one shot all over the car for all the rust i have inhailed putting structure back into his merc
