Technical Does anyone make Radiator hoses for SBC to '29 Model A Radiator?
Discussion in 'The Hokey Ass Message Board' started by Kid Rocker, Feb 10, 2021.
  1. Kid Rocker
    Kid Rocker
    Looking for some radiator hoses for small block Chevy to 1929 Ford Model A radiator.
    Any help is greatly appreciated!
  2. Rusty O'Toole
    Rusty O'Toole
    They make thousands of different shapes and sizes of hoses. Make a mockup of what you need. You can use some heater duct taped together to make it rigid, or stick pieces of old rad hose together, even bend an piece of wire. Then go to the parts store and ask permission to look through their stock of hoses until you find one the right diameter that has the right shape or curves to it. You will probably have to cut it down to size but that is easy with a utility knife.
    Kid Rocker likes this.
  3. Look at the tri five V8
    Kid Rocker, olscrounger and Just Gary like this.
  4. 51504bat
    51504bat
    IIRC @HOTRODPRIMER posted about using VW heater hose for mocking up what is needed to take to the parts store to see what will work. Makes sense to me.
  5. Pat Thompson
    Pat Thompson
    Oreilly's sells the old silver heat tube that went from the air breather down to the exhaust manifold. It works great to make a pattern.
  6. mountainman2
    mountainman2
    Everybody makes one. They just hide it within other hoses. ;)
    Kid Rocker and 2935ford like this.
  7. 2935ford
    2935ford
    Yup, that's what I do! :)
  8. MCjim
    MCjim
    from soCal
    Been around forever...period correct!!
    Kid Rocker and Tim like this.
  9. At the bottom, a 1.75" Gates #20242 fits a SBC/29 radiator with just a tiny bit of trimming.
    On top, it depends on what thermostat housing you're using.
    -I used a swivel housing that angles up about 45* (Edelbrock #4817) and a 1.5" Gates #20380 cut in half fit perfectly.
    -The top hose on a V8 '55-57 Chevy V8 also fits nicely if the radiator inlet is centered.
    The engine in the pics is a 354 Chrysler Hemi with a SBC water pump & Speedway radiator. Hope this helps.:)
    Budget36 and Rice n Beans Garage like this.
  10. Budget36
    Budget36
    There also was a recent thread about a SBC in a 32 and and a few other part numbers listed. Within the past few days.
    Kid Rocker and Just Gary like this.
  11. Kid Rocker
    Kid Rocker
    Thanks so much!
  12. Thnx @Just Gary
    Been trying to get hoses for build also
    Just Gary likes this.
