does anyone know what this part on my a. compressor is called
Discussion in 'The Hokey Ass Message Board' started by punkabilly1306, Mar 9, 2009.
  1. punkabilly1306
    punkabilly1306
    from ohio
    this part is leaking and wont let my compressor build past 75lbs and i need to replace it but first i need to know what its called. It sits under the on/off housing (pressure switch) and then a black tube runs to the discharge tube. sorry for the dark pic but hopefully you can tell what it is
    thanks everyone
    bob
  2. gassman57
    gassman57
    Try searching your compressor on google by Mfg. and Model#...you may find a parts scemetic that answers your questions.
  3. punkabilly1306
    punkabilly1306
    from ohio
    i have tried everything under the sun to figure it out, when i called cambell and H. today i got put on hold for ever and a day so i gave up with that idea today
  4. jusjunk
    jusjunk
    from Michigan
    looks to me like a push in plastic line fitting? i used to be able to help but since i dont have a job i cant get that shit anymore but mcmastercarr.com has em . Ifin im seeing the pic rite.. got a better pic.. prolly 1/8 ntp to 1/4 nylon line.. I may have one in the garage but no garuntees..
    Dave
  5. jusjunk
    jusjunk
    from Michigan
    Im sure thats what it is but i need a better pic.. what the hell do i win anyway
  6. punkabilly1306
    punkabilly1306
    from ohio
    when i pulled the fitting it had a little brass piece in it that was broke...im going to get better pics now
  7. jusjunk
    jusjunk
    from Michigan
    yup the brass piece locks the plastic line into the o ring and the bottom of the fitting... if its what im seeing and is a 90 with a 1/8 tapered pipe thread (male)on the other end then mc master will have em.. I pretty muched switched where i used to work to all brass nickle plated as the held up better but mc master will have plastic and it will work..
    pm me if you need anymore help
    dave
  8. punkabilly1306
    punkabilly1306
    from ohio
    the piece by itself
    the piece with that brass insert i was talking about
    another shot of the fitting by itself
    and another of the brass pieces by themselves
  9. SlowandLow63
    SlowandLow63
    from Central NJ
    I have them at work if you're stuck Bob, but any auto parts store would have one. Its called a push-to-connect Synflex fitting. Just bring it with you when you go to the store. I know Ohio is a big state of nothing, so call me if you're SOL.
  10. SlowandLow63
    SlowandLow63
    from Central NJ
    NVM, thats not what I thought it was.
  11. jusjunk
    jusjunk
    from Michigan
    Ive never seen one with that kind of end so im learning something here...i used all push in to push in or pipe thread..
    Dave
  12. punkabilly1306
    punkabilly1306
    from ohio
    any idea what the two little brass things do?
  13. jusjunk
    jusjunk
    from Michigan
    Nope.. thats the wierd part... were did it plug in at ?
  14. SlowandLow63
    SlowandLow63
    from Central NJ
    Me neither, I didn't see the new pics til after I posted.
  15. jusjunk
    jusjunk
    from Michigan
    shit and i thought once again someone knew more than me .. :D
    Dave
    ps; smc, legris and everyone used one touch fittings but they dont have that shit in em :)
  16. punkabilly1306
    punkabilly1306
    from ohio
    it plugs into the bottom of the on/off pressure switch box and then the black line runs back and threads into the copper tube off of the compressor
  17. jusjunk
    jusjunk
    from Michigan
    I wonder ir its a pressure check type of dealy... did you google the compressor brand and try to find a schematic? I dont remember mine having any shit like that but ill look tomorrow cause there could be a different way . Matter of fact i think mine just has a pressure switch without any funky shit like that.. ill look tomorrow if it will help
    Dave
  18. punkabilly1306
    punkabilly1306
    from ohio
    ive looked everywhere for info on this model other then what the book says...it is a farmhand which is a offbrand of CH, but uses the same pump as a cambell hausfeld
  19. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Im thinking its an over pressure switch or sensor for your pressure setting..will it run without it? if it does will it stop at the regulators setting?
    is that hose that goes into it an air hose? or electrical lines?
  20. punkabilly1306
    punkabilly1306
    from ohio
    i havent tried running it without it, i figured it was there for a reason so i didn't want to break it even worse lol. that is an air hose coming off of the elbow piece
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I think its feed back for your pressure switch..when the tank reaches its set pressure it turns off the compressor until it needs more air than turns the switch back on etc..
    whos make? model?
  22. dbradley
    dbradley
  23. rotorwrench
    rotorwrench
    It seems like most compressors first have a presure switch to shut the thing off at the set psi then they have a relief valve to blow the pressure off the head or valve plate. Most compressors ususlly make a pressure blow down after they shut off.
    Kind of a guess on my part but it might be related.
  24. jusjunk
    jusjunk
    from Michigan
    doesnt tractor supply sell farm hand too? im gonna be out tomorrow and there is a store right down the road .. i could go look
    dave
  25. leon renaud
    leon renaud
    from N.E. Ct.
    for anyone needing compressor parts try " APWdistributing 1-888-279 9274" they just sold me a complete rebuild for my craftsman (Delillbliss) 6 HP 60 gallon oilless compressor head for less than 1/3 of what Sears wanted for the same parts !They deal in all brands of compressors and pressure washers.I dealt with Dave there lots of help.
  26. It's your unloader, there is a check valve between the tank and the compressor that valve is actuated by a lever on your solonoid and relievs the pressure at the compressor head for the next start up.
  27. zbuickman
    zbuickman
    That is my guess. I had trouble with mine and evenualy sweat a schader valve into a piece of copperline to fix it .... but its on the fritz again 4 yerars later.. this time Im putting a solenoid valve in there..... that should last:)
  28. jusjunk
    jusjunk
    from Michigan
    Ok i found it on the t/s site and they show the switch plain as day and the line running off of it.. I can stop by tomorrow if needed.. ill ask for the manual and look it all over .
    dave
  29. spooler41
    spooler41
    That piece is the pressure cut off feed line,it trips the power relay to kill the compressor
    till the air pressure goes low enough to let it turn on again. Don't try to run it till its been repaired, it may over pressure the tank /air system.V.R.F., you had it right,good call.
    ..........Jack
  30. it seems to be the head pressure release valve. When the compressor shuts down, the valve opens and releases the pressure inside the pump so it will not have to start against compression
