Technical Disc brake residual valve
Discussion in 'The Hokey Ass Message Board' started by John Pearl, Jan 4, 2019.
  1. John Pearl
    John Pearl
    Does the residual valve go nearer the front brakes or near the Master cylinder( master under the floor),
    Or does it matter.
    Thanks
  2. ironworker95
    ironworker95
    Sent from my SM-G930V using The H.A.M.B. mobile app
    LOU WELLS likes this.
  3. John Pearl
    John Pearl
  4. Bandit Billy
    Bandit Billy
    Keep as close as possible and they only go in one direction.
  5. nugget32
    nugget32
  6. Not a bit
    Elcohaulic and gimpyshotrods like this.
  7. nugget32
    nugget32
    thanks, didn't think so.
    Sent from my Chromebook 11 Model 3180 using The H.A.M.B. mobile app
  8. ironworker95
    ironworker95
    nugget32 likes this.
  9. hotrodmano
    hotrodmano
    from Norway
    What is "Disc-brakes" ?? :D
  10. They go in backwards just fine- they don't work that way but it's possible
    Atwater Mike and Bandit Billy like this.
  11. Bandit Billy
    Bandit Billy
    My dad tried to tell me something like that when I was reachin puberty.
  12. carlos
    carlos
    from ohio
    http://www.ecihotrodbrakes.com/catalog.html Check this out it will help these are GOOD people,The residual valves go on front and rear when the master cylinder is below calipers and wheel cylinders,I think one is 2 lbs and the other is 7 lbs,They hold just enough pressure in the line to keep fluid from draining back into the master cylinder
