Did I Just Kill My New Engine?!
Discussion in 'The Hokey Ass Message Board' started by 4woody, Mar 8, 2013.
  1. jhaas63
    jhaas63
    This situation sucks and any one of us could have done it. I really hope all is okay. This is what sucks about today's world...all of us are so damn busy.
  2. blowby
    blowby
    from Nicasio Ca
    I can only speak from personal experience, having done it probably 50 times in my life, as recently as a month ago, on two occasions, when I was getting water in my oil from a leaky water pump seal.
    However, in the interest of internet safety, don't do it!
  3. 4woody
    4woody
    Thanks guys- feeling a little better now (though there isn't any reason for it..).
    Could somebody give me a how-to, or a link to a good how-to, on checking the bearings. I didn't build the engine myself, and don't know what to do to check it over now.
  4. GassersGarage
    GassersGarage
    This reminds me of the time I took my OT daily in for a new clutch. When I left the dealership, the motor was rattling so I killed the engine and checked the oil. It was dry! I called the dealership, pissed and told them they forgot to put oil in it. They said to drive it back and they'll add oil. I said, "Are you out of your mind?". They said everything was roller bearing and it wouldn't hurt anything. (The car was under warranty) So I drove it back, they added oil and everything was fine for years afterwards.
  5. gemcityrenegade
    gemcityrenegade
    If it was just for a second then it's probably fine. A few min and probably not. I'd pull it and take it apart. Put new bearings in, probably new cam and lifters depending if they're roller or not. Maybe new rockers.. Damn man..
  6. DeucePhaeton
    DeucePhaeton
    I can't believe how many are saying, pray! It's an engine for pete's sake. Pull the pan back off and check all of the bearing. If they are OK you're good to go. If one or some are turned a little in a journal, buy new bearings and polish out the journals. It there is damage to the crank, take it out and have it repaired. Simple, and you won't have to pray 300 miles from home that a rod doesn't start hammering.
  7. Post Apocalyptic Kustoms
    from Outside
    Hate to say it, but it sounds F@cked.
  8. Mike51Merc
    Mike51Merc
    You could cross a busy street with your eyes closed only so many times before you get run over by a bus.
  9. Pull the oil filter, cut it open, if it is full of fine metal....you know the drill......
  10. saltflats
    saltflats
    from Missouri
    Maybe there is a fellow hamber in your neibhborhood that could stop by a lend a hand on how to and what to look for and not laugh to loud while helping.
    If the bearings are just scored and have not flaked off and put a bunch of shit in the oil passages you can roll new bearings in with out taking it completely apart.
  11. slammed
    slammed
    This sounds like the plan to take. Slip 'em a few bucks to look it over. Otherwise, you will never have peace of mind.
  12. Gene Boul
    Gene Boul
    I would pull the pan (easy without oil) look at the top half of several bearings and shine a flashlight on the cylinder walls. Also there could be issues with the cam and lifters.
    Regardless, you need to look!
    Note: I've seen blown engines do burnouts without oil! Relatively minor damage...
    The older I get the better I was...
  13. Rusty O'Toole
    Rusty O'Toole
    9 chances out of 10 it is ok. Fill with oil, start it up and see. If oil pressure is normal and there are no raps or bangs, no harm done.
    The tenth time you have a chewed bearing that will eventually let you down. If you don't feel like taking a chance, take the pan off and inspect the rod bearings for scoring. If they are OK the mains should be ok as they get oil first. Take off the main caps too if you want to.
  14. kenny c
    kenny c
    Don't be too hard on yourself. This has happened many times. I once rebuilt a 330 in an f500 and started it up with only wynns oil additive for assembly oil and it ran for years afterward with no problems. I also know of at least a dozen or more honda car motors that were driven at least a half mile that were fine after adding oil. It won't hurt to pull it apart and look it over. you may need nothing more than just bearings or nothing at all. Good luck.
  15. sunbeam
    sunbeam
    Years ago when working at a station they did a oil change and after the customer left they saw 5 new quarts of oil on the bench. Called the customer who lived 16 miles away and told him he said I'll be right back hung up and drove back. They filled the engine and it acted fine it never did cause problems.
  16. Hnstray
    Hnstray
    from Quincy, IL
    The posts to this thread really displays the B R O A D range of opinions on the HAMB.
    However, no one knows for sure what your particuilar engine's condition is at this moment.
    Bear in mind YOU are the one who has to shoulder any consequences of this unfortunate error.......not any one who recommends "just put oil in it and....."
    If you tear it down, and everything is okay, you're out maybe two hours and another pan gasket.
    If you tear it down and everything IS NOT okay, it's likely you've just saved yourself even more grief and expense by catching the problem before it got really ugly.
    Me, I like to eliminate as many problems as I can reasonably foresee BEFORE they happen........ and that seems to have served me well for many years.
    Ray
  17. pitman
    pitman
    I thought the HAMB-er who mentioned re-fill, idle to warm up and check oil pressure was sound. Sure to keep an ear to the block to hear any new announcements!
  18. greazy john
    greazy john
    i go with Hnstray.....why take the chance.????????????
  19. Truckedup
    Truckedup
    If it was an engine in service for many years I would just add oil and motor on.But a new engine? No fucking way I wouldn't pull the pan ,pull each bearing cap and you can also look at the cam.
  20. BaBa
    BaBa
    Yes but then cut open the filter. This only costs you a filter and it is done all the time in avaition on every oil change. You can learn a lot about what is going on inside by checking the filter.
  21. mohr hp
    mohr hp
    from Georgia
    Note to self for next time; every oil change, as you start the engine, stare intently at the oil pressure gage. It should jump off zero within 5 seconds.
  22. Rusty O'Toole
    Rusty O'Toole
    To all those who think the oil filter is going to tell something about the condition of the engine. How is anything supposed to get into the oil filter when there was no oil in the engine? If there was enough oil to circulate through the filter there would be no chance of harming the engine. Not by idling for 5 minutes.
  23. falcongeorge
    falcongeorge
    from BC
    Oh oh, this has just taken a bad turn...
  24. slammed
    slammed
    Yes Ray, a broad range for 'we' are a diverse lot. From dirt poor drop outs to 'Ivy League' engineers. It is a microcosm of the world dare I say? Yes, I dare.
  25. B.A.KING
    B.A.KING
    pick one heads or tails. your call. just keep us informned. best of luck.
  26. If there is no oil how would there be any metal in the filter?
    If you put oil in the engine and run it the likelihood of doing more damage is greater than dropping the pan and checking the bearings,,I know it sucks but I would call the guy that built the engine and explain what happened,,pay him a few bucks to come check it out for you. HRP
  27. falcongeorge
    falcongeorge
    from BC
    considering that you didnt build the engine, I would call the engine builder, and either A) have him come over and drop the pan and check the bearings or B)Pull the motor and take to him so he take a look
    if both of the above are out of the question then Slammed's advice would be the next best solution. But A or B are by far the best solution at this point.
  28. 61 chevy
    61 chevy
    if you start it up, make sure oil gauge is reading 10psi or better, no psi, no bearing
  29. S_Mazza
    S_Mazza
    Well...
    ... Read all the posts in order and they make more sense.
    If there is loose metal, it didn't vaporize ... it will either end up in the pan or the filter.
    I guess it might end trapped up in a spot in the pan that doesn't drain to the plug very well. So this method is maybe not foolproof.
  30. BrerHair
    BrerHair
    We got Ivy Leaguer's on here? Cool.
    But you do point out 4woody's real problem . . . who to believe? Must say, it's entertaining (sorry 4woody, I feel for you).
