History Denver Heads ?
Discussion in 'The Hokey Ass Message Board' started by dechrome, Apr 9, 2017.
  1. dechrome
    dechrome
    I just bought a set of Ford 24 bolt aluminum heads at a swapmeet in Altamont, Il.
    I have seen Ford Denver heads and my recollection is that there were cast similar to cast iron heads externally.
    These are rather square shaped and flat across the head surface. The plugs are 18 mm.
    I have done a search in HAMB files and read about variations of Ford, Canadian and other cheater heads.
    These seem to have no marking. Any knowledge of this style or of history of these particular heads would be appreciated.
    Thanks
    dechrome IMG_1344.JPG IMG_1345.JPG IMG_1346.JPG IMG_1347.JPG IMG_1348.JPG IMG_1349.JPG IMG_1350.JPG
  2. 42merc
    42merc
    Kind of looks like a Thickston head.
    Appears to have bosses for the finned covers.
  3. 22 track
    22 track
  4. I second them as being Thickstun, they would have a finned cover held on with one bolt which threads into that center boss cast into the head. The Thickston logo appears to be missing however.
  5. dechrome
    dechrome
    Thanks for the replies. These do look like Thickstun heads. A further look appears that a logo may have been removed.
    Thanks
    dechrome
  6. Dak Rat
    Dak Rat
    from NoDak
    Hope you don't have trouble getting those old plugs out of there!
  7. treb11
    treb11
  8. dechrome
    dechrome
    An update on the Thickstun heads that I recently purchased. The plugs did come out and threads cleaned with a 18 mm tap. the gasket surface cleaned up on surface grinder and the corrosion cleaned with a plastic bristle rotary brush.
    This came from HF and is one product that worked. Surface corrosion was quickly cleaned without marking the aluminum, including plug pockets and valve pockets.
    biggeorge likes this.
  9. alchemy
    alchemy
    They look like they've been milled a lot. Not much dome left.
