Delco part number for Studebaker engines: 1110839 - All 1953, '54 and '55 V8 1110864 - All 1958 & '59 V8, 1960 289 cu. in. V8 only 1110869 - 1960 259 cu. in. V8 only 1110969 - all 1960 cars w/V8 (except Hawk) & all 1960-61 trucks 1110969 - 1961 259 cu. in. V8 only 1110864 - 1961 289 cu. in. V8 only 1110981- 1960 & '61 V-8 Larks, all (this is the "window-type" unit)
I just scrolled down through most of a page listing your posts to figure out that you are probably working on a 56 289 but it sure as hell helps you get information you are looking for if you have the sense to post exactly what engine or what not your are looking for the part for rather than a vague misspelling of the name of the vehicle. There is a Mallory for a later 289 Studebaker in Speedway's garage sale but chances are it won't fit. If memory serves right the only thing the same on those engines is the displacement. http://www.speedwaymotors.com/Garag...255-289-ZC-Double-Life-Distributor,55587.html Old Hamb thread with some info and some links you might use http://www.jalopyjournal.com/forum/threads/need-some-schooling-on-232-289-studebaker-v8s.
