I have been porting heads for a while as needed by a few customers and friends. The latest heads need quite a bit of cast iron removed and I would like to speed up the process if I could. I have been using double cut carbide ovals and flame shaped 6" cutters with pretty good results. I now see some of the venders are sell 55 degree spiral ( Drag Cut ) carbide cutters. Has anyone any experience using these? Do you have a dealer thats better then the others? Most of what I see are about the same price, in the $25-$35 range for extended length. The Drag cuts are twice that and the aggressive cuts are three times the price. Just looking for feed back before purchasing. Joe
The ports I do sometimes have to have a 1/4 inch off of some areas. A 1/2 horse electric grinder with double cut burrs saves a lot of time. I use pneumatic die grinders for finishing. Porting and root canals are about the same misery levels.
